Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Trio: humming and temp in freezer rising
Their was an intermittant (now for 24 hours) loud buzzing/humming. The repair man came last week and replaced a part but, the humming is continuing. Now the temp in the freezer is rising. Sounds like something is not "kicking on" when it is supposed to and the freezer is now not cold. Any suggestions?
Posted by ksheridan on
  • ksheridan Oct 30, 2007
    Thanks... the repair man is coming today I will give him your solutions!!
    It's the compressor. Has to be replaced!
Anonymous
    Scholar:
  • 146 Answers
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Posted on Oct 30, 2007
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The refridgerator is making a loud buzzing noise every minute or so. The fridge and freezer temp is rising. Tried to restart the power and that did not work
The compressor is trying to start but it is not starting....
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 28, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
The fan in my freezer was making a loud noice for several weeks as if it was having a hard time starting & now it is not working at all. The temp. in the freezer still remains the same. What will that...
Without a freezer fan the temp. in the frig will rise and the milk will spoil. After more days the temp. in the freezer will rise as well. Without a freezer fan the air is not moving, so naturally the the evaporator will ice up. Worst case the motor will smell like burnt. the frig will suffer 1st then the freezer. someone can get sick be careful. hope this was helpful replace the motor
Mar 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore side-by-side refridgerator is making a loud humming noise. My Kenmore side by side refrigerator/freezer has been making a buzzing noise every few minutes. Now I realize that the freezer is no...
You need to clean your coils under the 'fridge,' and wait 24 hours, if it is not not getting cold, perhaps replace the freon. If that does not work, you need to call a repairman.
May 26, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore trio 596
no it wont work, you can try replacing the overload relay assy mounted on the side of the compressor(football sized motor) behind refrig. i would check your manual for warr. information depending on age you may be covered for faulty compressor.
Aug 07, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Temp Fluctuations
i wouldnt worry mucha bout the fluxuations in temp, chances are simply a momentary reading perhaps just after a defrost cycle, sometimes new electronics can be a little too sensitive, I would only worry if you actually experience a noticable deiifeence in temp(ie.. your milk doesnt last as long, ice cream not hard as once was,, dairy usually best indicator in temp flux's))) dont worry so much abou the number, unlkess they are consistantly rising without correction
Aug 05, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer won't chill beyond fridge temp
compresoor sounds like its tryin to start but cant, should be covered under 5 yr manufacture warr.
Feb 21, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
382 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
