When i turn the key in the start position the scooter gives out a series of beeps and then five individual beeps but will not move.The battery is fully charged.
Iv got a monami wheel text and it will go forward but not backwards it starts bleeping what can it be
Posted on Nov 23, 2020
The 5-beeps indicates you are in free-wheeling mode. If the free-wheeling brake disengage lever is in the correct position then you likely have a bad brake switch or bad brake coil assembly.
Verify free wheel lever is in correct position and Replace the bad component if necessary.
Posted on Mar 16, 2014
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
SOURCE: We have charged the battery and when we turn on
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
SOURCE: the battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
Posted on Sep 22, 2009
Jul 09, 2018 | The Health & Beauty
Dec 17, 2015 | Health & Beauty
Sep 19, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Aug 25, 2014 | Health & Beauty
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
May 26, 2014 | Pride Mobility Products Health & Beauty
Apr 29, 2014 | Health & Beauty
Jun 03, 2017 | Health & Beauty
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
2,688 people viewed this question
My scooter is a Road Knight Micron.....Hope you can help.
