Ok i got a avic-d3 car dvd player but when i connect the dvd player to my car only the fan turn on but the front panel dunt turn on, no light, it dont show nothing in the scream so i woul like you to help me know what is the problem, i realy dont know is that dvd player have the anti-thif protection that i have to do something or what?
Did you hook up the wire harness correctly? Because you are not receiving power to the monitor. check these connections again. Maybe you have the wrong harness. Are you using the one from your car or DVD player? Did you splice the wires together? Do you have a correct color scheme to your vehicles wiring?
you may also need to bypass the monitor in order to view the screen while driving (if you're a rebel against johnny law)
SOURCE: it not turn on
Not sure what kind of connections you have, but be sure your unit is recieving good clean power. Try using another 12v constant and possibly a good 12v switched power source. Double check your ground wire as well. The unit may also be broken and might need service.
SOURCE: let my dvd player work
Have you or have someone bench tested it before installation? It is much easier to diagnose for problem when you bench test.
ok see i make a good conection but dont show nothing to the screen, just the fan turn on. but no light of the dvd player turn on. if one light turn on, i can say something but nothing show on the screen...
On cold mornings the screen on my D3 will not come up. Once the truck has been running it starts up fine....On the phone with Pioneer as I write this..
