Question about JVC KW-AVX800 CD Player
I want to connect a swi jack to steering wheel controller
How do i connect a swi jack to steering wheel controller on a vy berliner 2002
Is a suspension spring compressing tool needed to change lower control arm/ball joint front
usually when the spring is above and over the upper control arm you jack the center of the car up until the wheel clears the ground.
At that point the lower ball joint can be removed. Hope this helps.
Nov 30, 2014 | 2002 Mercedes-Benz C-Class
Bar that should be connected to front driver side wheel, it is broken off .approx.4-6 inches from the wheel, and I need to know for sure what the bar is
2002 Chevy Monte Carlo; connected to wheel (or steering knuckle) is:
-lower control arm, connects from frame to bottom of knuckle
-tie rod end, connects from steering gear to knuckle
-sway bar link, connects from strut to lower control arm
Nov 11, 2013 | 2002 Chevrolet Monte Carlo
Just wondering
Yes, you will need an item called a SWI-JACK by PAC.
Apr 23, 2013 | Cars & Trucks
I recently replaced a blown head unit in my vehicle with an aftermarket (JVC). during the installation I also installed a PAC SWI-Jack but when I tried to program it the button (any of them) on the...
I wouldn't recommend it because then you will have empty holes in your steering wheel. Plus if you do take them out you need to be careful not to set the airbag off.
Mar 02, 2010 | 2007 Honda Odyssey
How to intall PAC SWI-PS green and blue wires to pioneer AVH-P4100DVD
I don't think you install the green and blue wires to the actual deck itself you just plug the aux cord from the pac into the back of the deck the otherwires depend on your car
Nov 22, 2009 | AudioControl PAC SWI-PS - Pioneer and Sony...
I HAVE A TOYOTA RAV4 WITH RADIO CONTROL ON STEERING BUT CHANGE HEAD UNIT TO PIONEER AVICD3 AND WANT TO CONNECT CONTROL TO STEERING
There are a few aftermarket manufacturers that sell "adapters".... Check your local big box store, such as Best Buy, they usually sell and can install the adapter.
http://www.crutchfield.com/S-ay63JgSbNq0/p_127SWIPS/PAC-SWI-PS.html
http://www.bestbuy.com/site/PAC+-+SWIJACK+Steering+Wheel+Control+Interface+-+Blue/9553324.p?id=1218122911254&skuId=9553324&st=steering wheel control&cp=1&lp=3
Nov 04, 2009 | Pioneer AVIC-D3 Car DVD Player
Alpine CDA-9885 intermittent problems
you can try removing the faceplate and cleaning the copper contacts with a pencil eraser. This might help
Jun 15, 2009 | Alpine CDA-9885 CD Player
Steering wheel controls
change out the clock spring. i had this happen to me google the lincoln ls clock spring installation and then go to the dealership and purchase the part. it will run you about $138.
May 04, 2009 | 2002 Lincoln LS
Horn, Steering Wheel, Cruise Control
Replace the Clock spring. It is mounted behind steering wheel. It alows electrical connection while the wheel turns.
Jan 08, 2009 | 2002 Volkswagen Passat
JVC KW-AVX800 CD Player Logo
27 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
