Question about Home Fencing
Stanley 62 2043
How do you secure the tumb lach so it doesn't come out. There is a hole on it but no directions for what to do with it
Where can I get a spring for a stanley tr100 staple gun
Have you tried contacting Stanley directly? They are about the only source for parts for their tools...www.stanleytoolparts.com
Sep 06, 2014 | Stanley Tools & Hardware - Others
Sign in to my Morgan Stanley account-?
You should contact Morgan Stanley directly for the information, but it seems the client login is here: https://secure.ms.com
May 25, 2014 | Computers & Internet
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
Aug 21, 2011 | Stanley Utility Knife
Water dripping from right front of cabinet
The problem you're having is caused by two things. The drain hole near the rear of the drip pan is clogged and the downward tilt of the rear of the unt may not be enough.The general rule of tumb for rear downward tilt is 1/4" to 1/2".
The drain hole can be hard to find at times, as the clog often blends in with hole. Persistence and patience are needed to find it. A pipe cleaner works well to clear the clog.
Hope this helped you. Thanks for choosing FixYa.
Aug 18, 2011 | Haier Mechanical Air Conditioner HWF05XC7
1995 Chev Suburban rear door latch stuck in locked position
sounds like you lached the door
use a screw driver or some such tool
lift the outer handle and slip your tool in the middle of the lock hole in the door flip the lach open wile holding handle up
Dec 31, 2009 | 1999 Dodge Ram
Parts
I have the same sander, and cannot get parts anymore, so I carefully cut out a piece of sheet metal, and drilled holes, and put it on. so it might not say stanley, but who cares? I don't. and if it doesn't last as long, who cares. its more help than I got from stanley, who was bought out in 1973 from what I read.
Oct 18, 2009 | Stanley Hand Tools
I need a frog for a stanley no3 smoothing plane
I'd suggest that you contact Stanley Tools directly to find out whether you can still get this as a spare part.
http://www.stanleyworks.co.uk/Support/Contact+Us.aspx
Jul 27, 2009 | Stanley Tools & Hardware - Others
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
Jan 03, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Home Fencing Logo
450 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
