I think if I'm correct you are running to many speakers and have your ohm load to low for the amp causing it to go into protection. 1 single voice coil speaker equals 4 ohms for every speaker you have divide 4 ohms by number of speakers (ie. 2 single voice coil speakers equals 2 ohms or 1 dual voice coil speaker equals 2 ohms) this is for parallel wiring. For series wiring do the opposite if you have 2 speakers you are running an ohm load of 8 ohms the same for a dual voice coil ran in series. Series is positive on the amp to postive on hook up A negative of hook up A to positive of hook up B negative of hook up B to negative on the amp
It isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
so it might be the power wire?? one connected to the battery?
