Question about Olympus Camedia C-450 Zoom Digital Camera
What is the model of memory card
What is the name of memory card
I have money but how i can buy the memory card
take the camera to a camera store or an electronics store and ask them for a memory card to suit camera.
or
get model number and google model number and specs
then note type of memory card that it can take .
google this type of memory card to buy online.
Dec 17, 2016 | Cameras
Sat says unplug anything connected usb port as this can affect sat nav but nothing ever been connected also sim card gettiing hot
you need to keep it out direct sun light, if the sim card getting hot maybe the sim card is not compatible to that unit, blow some air through the sim connector port, it maybe dusty, or dirt in the contacts, try a different type of sim card good one like scandisk, or smartmedia memory card, make sure the sim card memory is not maxed out in the amount of memory that the device recommends, some time if it say 4gb dont put 8-64gb of memory in it, it will overheat and may start a fire. if you have problems contact the manufacture for more help.
www.ask.com/mfg.name/customer_service/
www.infolinks.com/mfg.name/FAQ
www.manualsonline.com/mfg.name/make/model/
www.eserviceinfo.com/equipment_type/make/model/service/
www.manuals.webcrawler.com/mfg.name/make/model/service/
Apr 21, 2015 | GPS
I have problems with card reader is not compatible with w in 8.1 pro
Hello
Probably you need to download Driver for it to use.
Hope this Helped
Apr 10, 2014 | Sony VAIO Computers & Internet
Targus card reader
First - have you ever used this memory card in this camera with this card reader connected to this computer - or is one or more "new to to the mix"? If so, which are new?
The obvious stuff is what I like to check out first.. check that the reader is connected to the computer's USB port (switch to a different port if it is and see if your computer displays a message indicating it is installing drivers / reading the memory card). Make sure the card is in the correct slot. Many readers can accept several different memory cards in two or more different slots - make sure you have inserted yours in the correct slot - and oriented properly. The card should slip in easily - not forcing should be required. Some readers maybe connected via USB "hub" that requires power - if yours is set up this way, make sure the power pack is plugged it.
Still nothing? Make sure there are images on the memory card. You should be able to reinsert the card into your camera and play them back on it. If they do play, remove the card and attempt to play them on the camera again - if they play this time, that tells me the images are in the camera's internal memory - not the removable memory card. You will need to transfer them from the camera - not the memory card if this is the case.
If you're still having trouble, please provide the camera & card reader name & model and if you're using Windows or something else. Finally, what is the name model and memory capacity of the memory card? Good luck!
Sep 16, 2013 | Cameras
I need another card that goes inside the phone, behind the battery. It's the memory card.I know what the proper name for but it just slips my mind, am sorry. I do have an excuse for this memory lo
Without knowing the make and model of the phone I can't be absolutely certain, but most phones that take a memory card take a microSD card. Some of them will also accept a microSDHC card, which is the same size physically but contains more memory.
Dec 25, 2012 | tracfone.com
I WANT TO UPGRADE THE GRAPHIC CARD ALSO THE RAM CAN YOU PLEASE TELL WHICH GRAPHIC CARD AND RAM WILL WORK ON MY MOTHERBOARD? Model Name : 8LD533 M/B Rev : 1.X BIOS Ver : 6.00 PG Serial No. :...
  1. Memory Type:DDR266( PC2100) 184 pin (2.5v)
  2. 2 x DIMM
  3. Max capacity: Up to 2 GB
Expansion Slots
  1. 3 x PCI (PCI 2.2 compliant)
  2. You can only used PCI graphic card not PCIE Graphic card
  3. PCI graphic card is hard to find now but you can try to find at any computer surplus shop
May 22, 2011 | Intel Motherboard
How do I format memory card
Welcome to FixYa.
I would be happy to help you and give you instruction on how you can format your memory card, however we need to identify what is the brand and model name of your camera.
Please reply the model name and brand for your camera and I can help you to format your memory card.
Thank you for using FixYa.
Apr 07, 2011 | Cameras
My 7610 supernova memory card has been locked how do we get it unlocked
We enable a password security on our Nokia phone to keep the data on the memory card private and not accessible to others. However, many times you may have come up across a situation wherein you have completely forgotten the password of the memory card or simply the access to the memory card is denied.
Even though you have tried your best to come up with all the combinations of the passwords that strike in your mind but all your efforts seems to be going in vain. Instead of panicking in such a situation, you can stay calm and perform a few troubleshooting steps to access the phone’s memory card.
One of the easiest ways to unlock or access a blocked memory card of your phone is to rename the memory card. Here are the steps you can take to rename the phone’s memory card:
  • On your Nokia phone, press the Menu button and go to Gallery> Memory Card (Please note the location of the Memory Card on the phone’s software may vary with different models).
  • Do not open the Memory Card folder but only highlight it and then select Options > Rename and put a new name to your Memory Card by replacing the old name and press OK.
  • Restart the phone and you will be able to access your cell phone’s memory card easily.
Sep 11, 2010 | Nokia 7610 Supernova Cell Phone
Unlock memory card
Password is the name of your memory card, so if you changed the name to your nickname or whatever that also acts as the password, although it doesn't say that at the time of doing it.
Feb 25, 2009 | Nokia N73 Cellular Phone
Olympus Camedia C-450 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
