We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
