Question about Jugs Small Ball Pitching Machine
Blowing fuse on small ball pitching machine
Have replaced the fuse 3 times and it blows immediately. Have only had it for a week and have not been able to use it.
Raul Carrion
    New Friend:
    Problem Solver:
  • 18 Answers
Are you using the right size fuse I would call jugs and ask them what fuse it takes you could also have a wire that's exposed and touching something metal look for that too
Posted on Jan 21, 2015
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
1994 cadillac eldorado - fuel injector fuse blows out randomly
Short to ground on the circuit intermittently , do you know what a short IS ? Finding active short
Mar 03, 2017 | 1994 Cadillac Eldorado
take a ohm meter and see if one injector has high resisance
Sep 12, 2012 | 1994 Cadillac Eldorado
Washing machine blowing trip?
It is best to disconnect the mains lines from the control panel to the different section, which are the motor, heater, inlet and outlet valve pump. If the fuse trips then the fault is the control panel board and could be a failure of the rectifier or SMPS driver. You might need to replace the board.
Jul 04, 2012 | Washing Machines
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
1999 Jeep Cherokee Sport The fuse that handles power for the instrument panel, radio, remote key, interior lights, ... blows from time to time. When I insert a new one the new one immediately blows as...
Not sure but I advised you before!!
Any way last time!
You have to t/s the moment the fuse blows and elimate the systems (short) connected to that fuse, for sample, dis connect the interior light, install fuse, if it blows than it is NOT the interior light, keep going till you find the short!
Aug 22, 2009 | 1999 Jeep Cherokee
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Jugs Small Ball Pitching Machine Logo
2,221 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
