Jura Capresso Jura Ena 3 Espresso Machine  Coffee Maker Logo
A
Anonymous Posted on Mar 09, 2014
Water is leaking from the ena 3
We find water on the counter beneath the ena
My Jura Ena 9 started by no water coming out during rinse cycle now no water comes out for hot water. It's leaking from the back bottom now.
It sounds like your Jura Ena 9 may have a clog or blockage in the water lines or pump, which is causing the water to not flow properly and potentially causing a leak. Here are a few troubleshooting steps you can try:
  1. Clean the coffee machine: Try cleaning the machine thoroughly, including descaling it to remove any mineral buildup that may be causing a clog in the water lines.
  2. Check the water tank: Make sure the water tank is full and properly seated in the machine, as this can cause issues with water flow.
  3. Check the hoses and connectors: Check the hoses and connectors for any leaks, blockages, or damage that may be preventing the water from flowing properly.
  4. Check the pump: Check the pump to make sure it is functioning properly. A faulty pump may be causing the water to not flow properly and could also cause a leak.
If none of these steps solve the issue, it may be time to contact a professional for repair or replacement of the machine.
8answers
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
How do I deactivate the filter function of JURA ENA Micro1 coffee machine
I pulled this info from the manual. I am including a pic and the link. Hopefully this is helpful.
If you do not want to use the CLEARYL filter cartridge Blue, you will need to set the water hardness. The following water hardness settings are available: Water hardness Symbol(s) shown in display Level 1: 1-15 °dH 1 symbol illuminated Y Level 2: 16-23 °dH 2 symbols illuminated Y < Level 3: 24-30 °dH 3 symbols illuminated Y < > & T Touch the Descaling symbol. The Y, < and & symbols light up. T Touch the Y, < or > symbol to set the water hardness, e.g. symbol Y for 'level 1'. The Y and & symbols light up. & T Touch the Descaling symbol. The Water Tank symbol M lights up. T Place a receptacle under the coffee spout. T Remove the water tank. T Fill the water tank with fresh, cold water and reinsert it. The Y, < and > symbols flash. The system fills with water and the water flows directly into the drip tray. The operation stops automatically. The machine heats up. The Y, < and > symbols flash. The machine is rinsed, water flows out of the coffee spout. The rinse stops automatically. The Ristretto Y, Espresso < and Coffee > symbols and the symbol for 'strong' coffee strength _ light up. Your ENA is ready for use.
https://secure.img1-fg.wfcdn.com/docresources/1803/27/278039.pdf
My Jura Ena 3 is leaking out the bottom.
First I'm not a JURA tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* If your leaking at or under the water tank then check for crack or you may be missing a rubber seal, o-ring, or washer. Replace the whole tank as a unit.
* If your leaking into the dregs or drip tray then there is a problem with the brewing system. Call for service. They may need to replace the brew valve or PC board.
* If your leaking at the bottom, drip tray, or side only when the pump buzzes (pumping water) then there is a cracked or disconnected hose line or fitting. Call for service and replace.
* If your leaking when the steam wand is in use then there is a similar problem with the 2nd pump system. Call for service and replace.
* If your leaking liquid coffee into the dregs tray or drip tray. Then you have a worn or missing group gasket(s). Call for service and replace. (you may find gasket kits from Amazon.com or online.)
* Final; Leaking water and electrical equipment is not a good idea. Best to be safe. Unplug and call for service.
Aloha, ukeboy57
PS: I've found the following video of a look inside the Jura;
https://www.bing.com/videos/search?q=jura+ena+3+leak&&view=detail&mid=741EFC1C3BEF3B6D9A49741EFC1C3BEF3B6D9A49&&FORM=VRDGAR
System is not filling in my Ena 3. Pump stalled despite several attempts to prime it. Any suggestion?
I do not know what efforts you made to prime the pump.
1- Make sure that the water faucet is open.
Use a hand pump to push water into the pump. You can use a syringe or a hand pump. See instructions attached. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Jura ena micro 9 error 5
jura Ena micro 9 PROBLEM. CAN NOT POUR WATER WHEN MAKING COFFEE
There is a massive leak coming from beneath my ingine. I never have had a problem in the past. The water rapidly drips but nearly pours out, leaving a fishy odor. I looked beneath where the water is c
could be a water pump,or a hose clamp is loose on bottom radiator hose.You will have to follow leak to find problem.You can take to Midas and tell them to check exhaust and they will raise up and see your leak and show you where it's coming from.
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
2helpful
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
