Question about Sony KP-57WS500 57" Rear Projection Television
I have a double picture on screen i could hear my TV but the color are off too with Sony RM-Y908 Remote Control? which is broke
Posted by karita16 on
  • ms9139 Feb 01, 2009
    the colors are all separated and there is a triple image, also the picture is arcing on the top and bottom silimar to word art in microsft word...any suggestions.
Edward
  • Sony Master
  • 3,459 Answers
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
I have a double picture  on screen i could hear my - 701cb04.jpg I have a double picture on screen i could hear my - 77ea520.jpgmg src="/uploads/iI have a double picture on screen i could hear my - f0900cb.jpg20.jpg" alt="77ea520.jpg" class="h_mi" />
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all dI have a double picture on screen i could hear my - 2c07611.pngour convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
Anonymous
  • 59 Answers
You need a tv service tech to change convergence amps
Posted on Oct 31, 2007
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My rm-v310 remote commander is not working for my sylvania tv
Your TV IR-receiver is broke. Its common with Sylvania TVs. Sorry. must be repaired by a local repair shop.
Sep 06, 2010 | Sony RM-V310 Remote Control
Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
Aug 25, 2009 | Sony RM-V310 Remote Control
My tv is stuck in picture and picture mode with a split screen
this a prb with u r picture tube...u jus call u r service provider...they will take care of u r tv...
Jul 25, 2009 | Sony RM-Y135 Remote Control
What is sony tv code for sky remot contrl
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0000
SELECT
cheers
Little Dish Fitter
Jun 07, 2009 | Sony RM-Y908 Remote Control
Av 1 stuck on sony tv screen
Press Display / " i " Button on TV remote, on-screen display will disappear.
Jan 26, 2009 | Sony RMT-833 Remote Control
Can not remove pip from sony 47"
hello just looked at the remote theres guide button next freeze press that should take you back to normal tv if that don't work get back to me
shaun
Jan 24, 2009 | Sony RM-Y908 Remote Control
How do i get my tv to show the picture straight
THE IS A BOTTON FOR THE ALIGNMENT UNDER THE POWER BUTTON. CLICK ON IT AND SEE IF IT CLEARS. IF THAT DON'T WORK LOG ON TO THE WEBSITE BELOW AND READ ABOUT THE COLOR ADJUSTMENT FOR THE SCREEN VOLTAGES. IF THAT DOESN'T CALL A PREFERRED SONY REPAIR SHOP FOR ADVICE.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Oct 29, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
198 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
