Question about Polaroid FLM-3732 Television
Buzzing TV- Polaroid 37" FLM-3732
I have a 37" Polaroid LCD (FLM-3732) that recently started making a buzzing sound when it is turned on. It started a little over a month ago and it only buzzes for around 15 minutes, then it won't do it again until its been turned off for a while. I was wondering if anyone has any similar happenings with their TV and if so, what I can do to fix it.
Posted by DAC0428 on
Brian Baber
    New Friend:
  • 19 Answers
I fixed one by put 2 new caps in c112 and c113 1000uf 10v
Posted on Nov 15, 2011
  • Brian Baber
    Brian Baber Nov 15, 2011
    on the power supply
Anonymous
    New Friend:
I am having the same problem with my Polaroid 37 inch lcd tv. When I turn it on for the first time it buzzes and there are lines across the screen. It stops after about 5 minutes....Any idea what causes this? The tv is only 4 years old.
Posted on Oct 11, 2010
Actually it's a poloroid FLM-3732 37 in. It buzzes/whizzes when I turn it on. Picture and sound are clear, however.
Probably due to a bad solder connection on one of the inverter board transformers. If the problem persists it will burn a hole through the board. An open transformer will cause the set to shut off. This should be repaired by a qualified technician.
Jan 17, 2011 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid 37 in LCD TV
combination of loss of your power supply and blown resistors take it to a shop
Aug 30, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Tip
Polaroid FLX-374 Manual Download
Download Polaroid FLX-374 LCD HDTV Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLX-374 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374 LCD HDTV Users Guide?
Follow this link
(& click FREE) to download a pdf version of the operations manual.
I hope that helps.
_____________________________________________
Polaroid FLX-374 Service Manual Download
on May 01, 2010 | Polaroid FLX-374 37 in. LCD TV
Hissing sound when turned on and goes dark when sound stops.
takes long time for tv to come on, there is a loud buzzing sound and poping noise
Mar 16, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
When i turn my tv on i get a buzzing sound for about 5 minutes then it goes away
mine did that then it would not turn on after a couple of weeks, the blue light came on but no picture. I changed 2 caps and fixed everything. check out this website, http://plasmalcdtvrepair.rankwell.net/2009/03/lcd-tv-problem-polaroid-model-flm-3732.html
Oct 30, 2009 | Polaroid FLM-323B Television
Buzzing sound
Hello, This is a problem with the switching transformer or the ballast used to fire the backlight. You will have to replace the ballast and or the switching transformer soon. In order to replace these items, I would suggest taking it to a qualified TV technician for servicing. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
