Question about Amerock Hardware & Accessories
Door handle with loose play
Tight to door but up & down movement
Posted by Rudy Sather on
Michelle Balcom
    New Friend:
  • 87 Answers
Remove lock from door.The round part contacting door usually spins to accommodate different width doors. This will pull the assembly together.
Posted on Jun 25, 2014
Fix loose door handle on a LG LRSC26911TT
if yours doesn't have the allen screw on the handle, you have to push the handle down(pushing it from the top) you might need a helper because it's really tight. I had a hard time removing those handles
Nov 22, 2017 | LG Refrigerators
Door handle has come loose from inside . Can lock and unlock but not open door with outside handle
If you take the inner door panel off and have the window up, you should be able to access the area to tighten the handle down. If the handle assembly is still tight, but the handle its self seems to have no resistance, the plastic clip where the release rod attaches may have broken.
Oct 05, 2010 | 2009 Dodge Journey
Door does not shut tight--bad latch???
usually the door latch will go bad when the door hinge bushings are very worn. Inspect the door hinge by holding the door a grab the outside door handle and the door shell firmly. Now lift the door up vertically and see if there is any play in the hinges. If the slightest movement is found replace the door hinge pins and bushings. your door latch may work great again If not replace that too
Apr 04, 2010 | 1990 Ford F250
Loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
The door handle is loose and i cannot tight the screws i dont want to call a repair man why would they make it difficult to tight the door handle .it cannot be difficult something to make a dollar this is...
mine was the handle was loose on the door not the coil in the stainless problem . i will try and figure it out my self i will not pay to have the handle tighten
Apr 05, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Door handle loose on 10656542400 kenmore
The solution on the Kenmore 56822 turned out to be very simple:
With the door closed, pull up on the door handle (requires some force). The door handle will slide up, and once it is up, it can be removed by carefully pulling it off of the door. Then the screws holding the mounting lug can be tightened. Place the handle back on the door, and slide it down, and voila, no more loose handle. I am going to put some LockTite on the screw on mine to ensure that it stays tight.
Nov 24, 2008 | Refrigerators
Jack the car up the wheel is loose would it be the bearings or axle
The obvious (which you probably already did thing to check lst --are the lug nuts tight, is the center spindle nut tight. It could be the bearings,but I would then check your ball joints or tie rods. Grab the tire at the top and bottom, try to move the tire in and out. Have someone watching the ball joints to see if there is movement (aka, play, they are loose). Next grab the tire at the front and back, and again try to pull it in and out while someone watches. If you can see movement in these components, they should be replaced asap (car won't handle as well, tires wear out quicker, etc) good luck countrycurt0
Aug 14, 2008 | Pontiac Grand Prix Cars & Trucks
Loose door handle
If a tight place is worn out, then try warmer temperature and go to the tools store to place the door with your new tools.
Aug 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Hardware & Accessories Logo
122 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
