Question about Toymax Magnavox 37MF337B 37 in. LCD TV
We have a magnavoxn model 37mf337b/37 and as soon as it is turned on about 30 seconds it turns off why
As i said after 30 seconds it turns itself off ,when turned back on again it turns off
Posted by rhonni bollier on
1helpful
Tv powers on and after a few seconds turns off. does this several times then will eventually stay on
hi this may be a power board fault, usually capacitors that bulge up or shorted transistor or diode
regards
shaun
Magnavox turns on then goes off model 37f337b/37f437b
More than likely power board,usually repairable,look for blown capacitors.A blown capacitor will look like the top is rounded also suspect capacitors will show signs of the plastic coating shrinking .
1helpful
Philips 42pfl5432d/37 tv chirps when power is on
Usually stems from a short on the power supply board. I have a 37MF337B/37 37" that had the same problem. Turned out the set had 5 leaky capacitors and a shorted diode on the power supply board.
Magnavox tv turns off by itself
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal
regardsshaun
I have a 37MF337B/37 tv. i have had it for about two years and recently over the last few weeks i cant get it to turn on. i have a redlight in the front but it will not turn on and go green. I have tried...
there is a bad capacitor in the power supply you will see it it is all alone and will be vented or buffed up on the top..the value is written on the side just replace it and you will be good to go
Sometimes when I turn on my Magnavox 37MF337B tv it emits a very loud squeal and the picture/channel locks up. I cannot turn it off with the remote. I have to unplug it and try again. When it is on though...
you have some bad caps in the mainboard very common on this model the can shaped devices will have a puffed up top i would suggest you have a tech reaplce them they are hard to get out due to the large ground plain on the board you need a good hot iron
Magnavox 37MF337B/37 Speaker Problems
It needs a small signal board, it is still under warinty, up 1 year after you but it, look in your manuel, or on line for there phone number call them, asap, they should set you up with a service center, and they will cover part and labor
Magnovox: model 37MF337B/37 My Magnovox TV changes channels and even turns on and off by itself... I believe its a defect, but want to ask if this is something that has been heard of or reported. please...
There arethree possibilities that cause this symptom.
1. The buttons on the TV are shorted and must be replaced.
2. The firmware must be upgraded.
3.The main bd is bad and must be replaced.
Toymax Magnavox 37MF337B 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
