Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
Hair in a Jacuzzi Drain
Hi! Our jacuzzi has only been installed about 6 months. My daughter showers in it every day and I think hair is getting in the drain. There is often standing water in the tub after she showers. Is there a way to remove the plug for showers and use a strainer? And then use the plug, or some other generic plug, for baths?
Posted by Apsannah Coccia on
US Parts Center
  • Jacuzzi Master
  • 719 Answers
Take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Posted on May 25, 2014
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Posted on Feb 03, 2009
Anonymous
  • 152 Answers
SOURCE: Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
Alan
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
NOT ME
  • 2841 Answers
SOURCE: Faucet placement on Jacuzzi 6036
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like. a1da3ad.png
Posted on Jan 08, 2010
Anonymous
  • 120 Answers
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Posted on Jan 20, 2010
How to remove hair/dirt from shower drain?
Buy a cheap pair of hemostats at your local hardware store. Get the long one.
Jul 07, 2014 | Home
I am missing the drain stopper for a Jacuzzi Signa 6 whirlpool. This is a round disc with a short metal stem on its underside.
Drain plugs on bathtubs are generic in size. Jacuzzi does not make them. They are made by other Mfg and installed by your local plumber when the tub is installed.
US Parts Center
Oct 28, 2013 | Jacuzzi Home
My bathtub is draining very slow and I cannot figure out how to remove the stopper to clean out the problem (which is most likely a lot of hair). It is brand new...only like 6 months old...Delta brand.
On most drains, the top of the drain will unscrew, and then you can get to the rest of it. Sometimes you will have to take a pair of pliers to turn it, but it should come off.
May 28, 2011 | Delta & Single Handle Shower Faucet
I can see outside of tub get wet and it leaks by the drain..its brand new..only does it when its drained after being filled to a high level..is it cracked or something? can't see any but dont know what...
If it only leaks when filled to a high level, the rubber washer behing the overflow plate is misaligned or missing. this plate is on the tub wall above the drain, and hld in in by 1 or 2 screws.
Oct 05, 2010 | Jacuzzi Home
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
I purchased a very nice and expensive jacuzzi 60 X36 shower base in oyster and had it professionally instlled in new construction a little over three years ago. A week ago when using the shower I heard a...
some shower bases require additional support,I would call jacuzzi and explain the problem.If 6the unit required more bracing you will probably have to reach the contractor who put the unit in,then go from there,but this day and age it is hard to get satisfaction cause no one wants to be liable for labor and product.good luck hope you get satisfaction from one or the other!
Jan 25, 2010 | Jacuzzi T362-969 Tru-Level 42 X 36 Shower...
How do you get hair out of a drain that is in a Jacuzzi. Can I unscrew the drain stopper or can I remove the chrome plate further up the tub?
unscrew what ever is covering the hole where the water drains out,.... use a pair of needle nose pliers or an old coat hanger with a little hook pre-bent in it (don't get it stuck in there) and pull out the hair,....it's that easy! good luck, cracklin joe
Jan 04, 2010 | Jacuzzi Rotary PVC Drain Kit DA34-815
Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
Mar 17, 2009 | Whirlpool Home
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Dec 12, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
129 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
