Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse LTV-32w1 32 in. HDTV-Ready
I have sound but no picture.  The signal is on TV and it still doesn't work!  It worked fine before and suddenly went blank.  I need help right away.  Thank [email protected]
Posted by tattlerwest on
  • 9 more comments
  • Marty Hollas Dec 28, 2007
    I am having the same issues with my brand new 32" westinghouse LCD (SK-32H240S)
    It appears, at random, to suddenly lose the picture (screen goes black but not off, sound continues normally)
    The only thing that seems to bring the picture back is turning the power off and on. I have had it set up for 2 days, and it has happened at least half a dozen times... thinking of returning it....
  • Anonymous Mar 20, 2008
    I have LTV-32w1 I hear sound but no picture I no is either the inverter board or the main board I not sure what to replace.I just want what causing the picture not to show
  • lis4short Apr 14, 2008
    I have sound but no picture it was working fine then went blank screen
  • Anonymous Jul 10, 2008
    the screen is blue with no picture but the sound is coming in
  • argentile Feb 02, 2009
    I have the sk32h240s and the same problem. Unfortunately the advice on unplugging and replugging the cord from the back of the television did not work. Any other suggestions would be appreciated.
  • conbag Feb 08, 2009
    Picture comes on for approximately 1 second, then goes blank. Sound and channel selection appear to be fne.
  • Anonymous Feb 25, 2009
    this problem would cost approx $400.00 to fix plus shipping
    I just got a new tv---and btw it was not a westinghouse
    best buy said they have had this problem before with this tv so if you didnt buy the warranty you are SOL and the westinghouse help line is terrible
  • Anonymous May 12, 2009
    I tried the unplugging while it was on and it did not help. One other thing, when it turns on, the W that shows does not stay on as long as it used to. Any other tips before I pay a serviceman to look at it?
  • dmwein May 11, 2010
    on my unplugging the pwer and plugging back in didn't work, You can see a fait picture at the right angle any other thoughts
    how do you change the energy star if you don;t have a pciture
  • Anonymous Mar 13, 2014
    Tv was fine then all of a sudden no picture. Completely snowy but sound is still great on the surround sound. Called due to storm and time warner said no outages in area....
Anonymous
Its probably a broken backlight inverter, it costs about $130 for a new 1, and thats if you install it yourself, which shouldn't be too hard You can probably find instructions online about how to do that (P.S. Check before buying and trying to install yourself.)
Posted on Nov 23, 2007
Anonymous
Got impatient and opened the rear panel. Turns out, one of the transisters has a burn mark and a melted spot on the LCD/LIPS inverter. Easy fix if you have the money. 159.99 for the replacement LIPS board on www.lcdpart.com. part number 4H.B0700.051. I have not yet fixed mine, waiting on funds to increase. 8 plugs and 6 screws and you got er fixed.
Posted on May 12, 2009
Anonymous
I read on this site that unplugging the power cord from the back of the tv while it's on and then replugging back in works. I had the same problem as you along with the controller not working. When I tried this suggestion, I was very surprised that it worked. The tv and controller both immediately funvtioned properly. I assume there must be some sort of "rebooting" that takes place. Anyway, good luck.
Posted on Dec 05, 2007
Anonymous
We had the same problem...screen would either go into lines or just black, but sound would work perfectly. Our Westinghouse is only 1.5 y/o, we took it to HDTV repair shop and they said it was the main signal board which would cost $300 plus labor! We are now trying to sell the TV and just bought a SHARP.
Posted on Oct 20, 2008
rasherrard
Man are a life saver!!!! I unplugged the TV and it works fine!!!!! THANK YOU!!!!
Posted on May 03, 2008
Marty Hollas
I tried unplugging, but the problem came back after a day.
I think there are some issues with the energy saver when set on normal. After a while of being on this setting the problem occurs. Modifying this setting to E-Saver seems to have solved the problem. TV must have problems entering or coming out of sleep mode is my guess... been working fine for me for a week now after making the change.
Posted on Jan 09, 2008
Anonymous
Sound and LED OK no Picture or menu... What rbresli posted worked Thanks!!
Anonymous
I had the same problem and rbreslin's solution worked!!!! Turn the TV on and while it is on, unlug it and waia few seconds, then plug it back in.
Posted on Feb 25, 2009
1 Related Answer
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Westinghouse LTV-32w1 32 in. HDTV-Ready
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
Try these first and let me know how it goes..
Posted on Jun 08, 2008
Jun 08, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-37w2 loses picture
Hello, you are getting some signs that your inverter boards on this unit are going to go out. By the sounds of the problem you could have a loose cable in the master or the slave inverter, or it is just an indication that one of the two is about to give out with in the near future. You can find these parts by visiting www.shopjimmy.com.
Apr 19, 2010 | Westinghouse LTV-37w2 HDTV
No picture on Westinghouse flat screen tv
westing house flat screen tv hd...has sound no picture
Feb 15, 2010 | Westinghouse LTV-37w2 HDTV
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Display Issue; Sound, but NO Picture!
if you have cable tv try unplugging and plugging in that cable if that doesnt work you might have a bad cable. check for damage along the cord or bends in the metal ends sometimes that can also be the problem
Jan 09, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-40w1 HDC HAVE SOUND - NO PICTURE
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
[email protected]
Jan 01, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Power up problems
Does anyone know what the part number for this elucid power supply would be? My TV is doing the same thing, so I'm trying to find one so I can swap it out.
Apr 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
4,000 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
