Have a base and two extensions. base and one ext. get nodial tone, but receive messages. the other ext. works fine.
SOURCE: All of the sudden the phone just stopped working. It says 'out of range'.
remove battery from handset then unplug base from power supply. Reinstall battery in handset then plug base back in to power.It worked for me.
SOURCE: Out of Range Message
The phones need to synced back to the base.
Have you had a pwer failure or blackout recently this will nock them off line
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
SOURCE: searching and out of range message keep appearing.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
