Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Black line half way down the center of the screen,about 1.5 inche
Is this fixable and if so how
Posted by jbrudnicki on
Anonymous
  • 335 Answers
There's a 'data control' and/or 'address' problem that's developed. Pixels depend on voltage, control, and data coming too their designated address.
A digital circuit feature called a 'DATA_ADDRESS_ BUS" are responsible for 3 criteria: Delivering voltage, control, and data to each pixel in less than a second.
1) If voltage fails the pixels don't light up. They appear black in color (their 'off 'state)....numerous pixels that don't light up look like a black line. But their actually individual pixels with no voltage.
2) If control fails then all pixels are white in color (their 'on' state). Without control the pixels can't adjust properly to high or low 'state', meaning brightness and dimness. This looks like a white line vertically on the screen.
3) If data fails then the pixels can't adjust to the proper color at the proper time.
This appears as a line that changes color out of sync with the entire picture.
Have a technician look at the pixel address registry circuits. As well as control and linear circuits....the problem is somewhere in there!
Posted on Jun 13, 2009
1helpful
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
2helpful
4answers
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
2answers
There is a scratch on the screen and it's getting bigger, well it was scratched now there is a solid colored line. What do I need to do? Is it fixable? It started as a scratch about 1/2 inch now there is a...
Unfortunately it is NOT a "Scratch"... actually it is one of the "Row Driving IC's" that is failed/failing, this will only get worse and eventually it will get more & more. Worst of all there isn't anything that can be done, sorry.
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
2answers
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
1helpful
2answers
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
1helpful
Panasonic TH-50PZ77U 1 1/4" inch vertical line
This problem is usually the ribbon cable connection at the top of the stripe. Reseat the cable first. The other possibility is the panel itself, but that is rare.
Keep us posted.
Dan
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
Top Toshiba Televison & Video Experts
Ekse
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
