Question about Bosch Axxis WTL 5410 Electric Dryer
LG DLE3777W STOPS BEFORE CLOTHES DRY - Bosch Axxis WTL 5410 Electric Dryer
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
How do I remove the entire lint unit to clean?
Can you get a long magnet to fit in and fish out the screw driver? Or bend a clothes hanger into a small hook shape enough to hook the screw driver .
Jan 17, 2015 | LG Tromm Control Panel AssembFront Load...
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg dle3777w will not dry load completly. Stops drying and load will still damp to slighty wet. Do know what might be the problem?
unplug dryer,remove front paner, at heater element Box check the smaller therma fuse at rear by disconnecting one terminal and using a continuity meter measure the part. if you hear no beep then replace it.
Feb 14, 2011 | LG DLE3777 Electric Dryer
I have an LG DLE3777W electic dryer that was making a sqeeking noise but is now making a banging and vibrating noise. I think the bearings are gone. I do not have a prts manual so I do not know what to...
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
I don't know how quickly you need the parts, but on eBay they are cheaper:
http://shop.ebay.com/i.html?_nkw=dryer+drum+rollers+&_sacat=0&_odkw=dryer+drum+rollers+and+glides&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope this Helped Tim
Jan 18, 2011 | LG DLE3777 Electric Dryer
We have an lg dle3777w dryer and it doesnt seem to get very hot to dry the clothing...it takes many cycles to get one load dry...any ideas???
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE3777 Electric Dryer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Loud thumping noise has resulted in penny size hole in the drum.
Check your owner manual some LG had life time warranty on there drums..if so call for service..
Sep 21, 2009 | LG DLE3777 Electric Dryer
My LG electric dryer DLE3777W takes forever to dry as it does not get hot enough. Suggestions?
Check to see if your vent is not kinked or clogged. Also, check if your lint screen is clean. If you don't clean it each time you loose 10% efficiency. Good Luck
Apr 13, 2009 | LG DLG5932W Gas Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
Vernon Taylor
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
