Question about Olympus Camedia C-2020 Zoom Digital Camera
Does 2020z use dram? - Olympus Camedia C-2020 Zoom Digital Camera
Posted by Roger Prince on
Harrie
    Top Expert:
  • Olympus Master
  • 6,746 Answers
No it does not use dram. It is not a PC
Posted on Mar 09, 2014
What ram for
RAM is a type of computer memory accessed randomly during hard drive processes.
A computer's RAM is considered "random" because any byte of memory can be accessed without processing previous bytes.
Purpose of RAM
RAM is used to load and run programs or applications on a computer's operating system. More RAM means more applications and programs can be run simultaneously.
SRAM
Static Random Access Memory, or SRAM, stores data on a computer in a static method, meaning the data stays the same with power being supplied to the memory chip. SRAM is the faster RAM when compared with DRAM.
DRAM
Dynamic Random Access Memory, or DRAM, is a type of memory used in personal home computers. This type of memory must have an electrical current to refresh. DRAM is used more commonly because it's less expensive to manufacturer and install in chips.
EDO RAM
Extended Data Output, or EDO, is a new type of DRAM chip that uses technology to add 10 to 15 percent more speed than normal. A computer that uses EDO technology must meet the chip requirements or the EDO will not be recognized.
FPM
Fast Page Mode, or FPM, is a RAM speed enhancement that uses rows of bits selected in columns and rows of the memory.
FPM is used in EDO RAM.
2answers
Error memory test.
Sounds like the DRAM failed the Self Test.
Power cycle the printer and if the error doesn't come back, go about your business.
If the error comes back, you may have to reseat the DRAM and try again. If error repeats
the DRAM may have to be replaced. Electronics Module may have to be replaced if DRAM
doesn't fix it.
Konica minolta fax 2900: dial waiting with strange symbols on the display screen. can not receive or sent fax.
Your DRAM or DRAM may have become bad. Try clearing DRAM and SRAM via Service mode.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
What are errors 1to5 and 7to8
1- face down sd ram failure
2 face up dram failure
3 cpu dram failure
2helpful
2answers
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
3helpful
My Xerox Phaser 6110MFP got error "Internal Error WER OFF/ON DRAM-FUNC.C 58 R". Cannot get solution from any sites. Can't use printer. Please help, thanks. [email protected]
DRAM TEST
Use this feature to test the machine's DRAM. The result appears in the LCD display.
If all memory is working normally, the LCD shows << O K >>
Help for a novice !
you should be able to set the shutter speed to the longest setting and do this. The setting is limited to the max programmed length I believe, which on the 4040 is 16 seconds.
Olympus Camedia C-2020 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
