Disasembly
Hi Paul,
I have this site for you on how to do transfer belt on your machine. Hope it helps.
Samsung CLX 6200FX User Manual Page 68 Replacing The Paper Transfer Belt
SOURCE: Samsung CLP-300N was asking to replace transfer
open the top cover press and hold the main button wait for the 3 lights to go up, release and cover
SOURCE: samsung CLX-3175FN printer instructions - How do
3175fn is acolor printer. if you want to set only grey or black only print. you have to go to printers & fax. select the printer right click properties and go to color and set as gery or black only print.
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
