Microsoft Xbox 360 Wireless Controller Logo
Question about Microsoft Xbox 360 Wireless Controller
Left analog getting stuck
Feels like my controller is getting stuck from time to time is it dirt in their and my left analog don't click in when u push it for a swipe on call of duty what do i do buy a new controller or is there some way to fix it..
Posted by Steven Bullock on
Luis Robles
  • 25 Answers
Posted on Mar 15, 2014
1 Related Answer
Anonymous
  • 86 Answers
SOURCE: Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Posted on Apr 10, 2009
Left analog stick My Xbox left analog stick does
Analog stick might be bad and may need replaced. If you don't feel comfortable tearing it apart, you may want to look into a new / used one.
19helpful
The left analog stick stuck to the left
You need to recalibrate the the analog sticks. To do this you need to take out one of the two batteries then press and hold L1 and L2 at the same time. While holding L1 and L2 insert the battery you took out earlier. Now you can release the L1 & L2 and your analog sticks should be centered. Do not touch or move the analog sticks during this process. If this fails to recalibrate then repeat the procedure again.
1helpful
Analog stuck
You need to replace it. The following website sells the analog assemblies as well as perform the actual repair for around $35! The joystick/analog assembly wears out after time. It's a very common problem with the PSP:
http://store.richspsxparts.com/pspanstasre.html
1helpful
2answers
Right analog on ps3 gets stuck on top left direction
the circular thing that lets it move freely probably cracked, making it harder to move. i had to buy a new controller because of this reason.
My left analog stick gets stuck in any of the directions that I push it in. What should I do?
I would replace the controller. It may be damaged. They aren't terribly expensive.
59helpful
3answers
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
1helpful
The left analog stick on my xbox 360 controller is faulty
In this game you must check your settings, you may be set to right handed in which case movement/advance is on the right side and attack is on the left. You should be able to go to settings and change the settings to make the left analog control your movement. Hope this helped and if it does, don't forget to leave feedback....FIXYA!
3helpful
3answers
Can't connect nerf ps2 controller to its receiver.
the L3 button is Left thumstick pressed inward
R3 is right thumstick pressed inward ;P
pls rate .
Analog stick getting stuck
your psp probobly has somthing lodged underneeth the analog stick like a pice of dirt or somthing very small.theres probly not much you can do yourself but you can take your psp to repair shops or some electronic stores that might be able to repare your psp and solve your problem...
2answers
Ps2 console
This sounds like problem with the controller pad.
It could be left direction button is stuck down or the analog control has fault on it.
If you have two controllers try swapping them round otherwise try to clean the one you have. Maybe give it a very gentle tap to loosen and dirt inside it.
Top Microsoft Video Game Consoles & Games Experts
David Shaub
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
