When i try to charge it on the regular charger its like the hole is too big and it slips out so i have to sit it a certain way to power it up please help.. do i need a new phone..??/ or the warranty helps..
SOURCE: my phone wont charge
The battery is literally dead. This happened to my iPhone 4 about a month ago. Fortunately I still had the warranty and took it to the apple store. They inspected the phone and replaced it within 20 minutes. All you data will be lost, but you can always restore it. They will not replace your phone for water damage unless you have an extended hardware warranty
SOURCE: wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
