The Emachines EL1358 has a wired LAN connection. To add a wireless connection, you need an USB wireless network adapter or an add-on wireless network adapter card. The internal card options may depend on exactly which EL1385 model you have. The EL1385G-51W has a PCIe x16 and a PCIe x1 slot. The card will probably need a low-profile bracket to fit in the case. (If both slots are in use, you'd need to remove one of the cards and replace it with the wireless adapter.) See
https://www.manualslib.com/manual/391363/Emachines-El1358.html for information on adding a card to the desktop.
Check that the card has a driver for your machine's OS version. (The EL1358 came with Windows 7. Windows 10 x64 requires signed drivers, if you upgraded to that OS version.) Follow the directions for the wireless adapter to determine if you need to install the drivers before connecting the USB adapter or installing the card. If there is no CD or USB flash drive with the adapter packaging, you will need to either download the driver files at another computer or use the wired LAN connection to obtain the drivers. (Use the wired LAN to connect to your WAN or router to obtain the drivers if they come from Windows.)
Once the drivers are installed, then you can enable the wireless connection. For several versions of Windows, go to the Control Panel. Find the section on Networking. Choose Connect to a Network. See if your wireless network SSID is listed. If needed, go to the Network and Sharing Center. Then find and click on the link for Set up a new network connection. You may need to Manually connect to a wireless network if the SSID of the wireless network is not being broadcast.
I hope this helps.
(note: slight differences exist in the placement of the network control panel options between Windows versions. I usually can find which one I want but have to poke around at times.)
