Question about Dell 1815dn All-In-One Laser Printer
DELL 1815 MANUAL PICKUP ROLLER
HOW TO REPLACE
Dell 2360dn printer manual paper feed settings
I know this sound hokey but it just worked on one new out of the box.
1 - Take the paper tray out.
2 - Flip the printer up on it's back.
3 - Pull the forms pickup roller out and remove white bands.
4 - Turn the bands inside out and replace them on the rollers.
Aug 18, 2014 | Dell B2360dn
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
How do I replace cassete pickup roller for Dell 2335dn?
David Wangaard,
You can click the link below to download the online manual. The manual provides information on replacing parts in your printer.
Dell 2335dn Printer Manual
http://dell.to/1nIznNt
Thank You,
Dell-Jesse L
Apr 28, 2014 | Dell 2335dn Multifunction Printer
Pickup roller
search trought service manual and see service menu for reset counter for pickup roller
Feb 03, 2014 | Samsung CLX6220FX COLMON MFC Printer
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
Jan 29, 2014 | HP LaserJet P2015 Printer
Dell 1600n pickup roller issues
The1600n pick up roller part number R5375 is probably cracked and otherwise in need of replacement. They cost about $20 - $50 from various sources. Try ebay and Amazon.com first.8_1_2012_11_46_03_pm.jpg
Feb 14, 2012 | Dell 1600n All-In-One Laser Printer
How do you remove the pickup roller to replace the rubber material?
Consult with the manual. Some models are easy to replace. If you take a good look at the pick up roller and watch how it comes off, just replace the same way.
Dec 01, 2010 | Dell 1100 Laser Printer
Paper won't feed
More than likely you pickup roller is dirty.
You can try to clean to see if that helps.
If that fails, then replace the pickup roller.
Below is a service manual that will show you how to remove and clean the pickup roller and how to replace it if necessary.
LJ1020 Service Manual
  • Pickup roller RL1-0266-000CN 50,000 pages Affects paper pickup
Sep 04, 2009 | HP LaserJet 1020 Printer
Need to replace pickup roller on MFC-7820n. I've purchased the Genuine Brother Paper Feeding Kit with Pickup roller assembly and Separation pad. A quick look indicates the pickup roller assembly...
Well, how to do that I don't know how to explain you, but first of all try to clean it, do it with thinner, this may solve your problem for while, at least until you find a way to remove and change.
Aug 14, 2009 | Office Equipment & Supplies
Dell 1815 Manual Feet
I WANT TO INNSTALL TUE PRINTHER ?
Oct 09, 2008 | Office Equipment & Supplies
Dell 1815dn All-In-One Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
