Question about Evenflo Generations
How to loosen the straps on envenflo tribute carseat?
The straps are too tight on my 9 month old
Posted by shaunettejd on
Anonymous
    Problem Solver:
  • 6 Answers
This is about all I could find for you. Hope it helps.
Had one - its a huge pain in the **** and I always busted my fingernails doing it. The metal clips have to slide over the bumps to get them out. I hated that thing. May I make a suggestion? Return it. lol . I'm figuring you got a combo seat - Evenflo Generations, Bolero, Chase, that is a forward facing only seat to 40lbs, or a convertible seat like Evenflo Tribute that is forward facing to 40lbs. Since I don't know her age its hard to make a suggestion, but for just a little more money (we paid $79 for our Chase) you could get a much better seat. If she needs a convertible that will rear face, get the Evenflo Triumph for $150 or less, The Evenflo Triumph Advance (not the original Triumph, make sure it says Advance) is a great seat. $150 version at Babies R Us has padding similar to Britax seats, top slots of 17", harnesses to 35lbs rear facing, and 50lbs forward facing. $120 Walmart version just has little less plush padding. Wide open belt path, easy to install, though it doesn't have built in lockoffs. The harness adjusts at the front of the car seat, you don't have to take the car seat out of the car just to raise/lower the straps. It's one of only 2 seats that does this (The Britax Boulevard is the other, I believE), and it has infinite harness adjustment so the harness always fits perfectly until its outgrown. No more tugging straps to tighten them either. You tighten and loosen the harness using knobs on the side of the seat. As a major bonus, it can be used in a recline position even in forward facing mode. Awesome for kids who still sleep in the car. I LOVE THIS SEAT! LOL My son, who is too big for every other car seat at Walmart has the same amount of room in this as the Britax Marathon.
If she is forward facing (over 30lbs and over 2years old) then a Graco Nautilus would be a lot easier to use and install, $150. Harnesses to 65lbs and then becomes a booster, will be the last seat you have to buy her. Metal reinforced.
Combo seats are usually a major waste of money, as they only harness to 40lbs, no more than most convertible car seats, so you're really not getting any more use out them then the convertible seat.
Posted on Jun 14, 2009
Straps too tight
Hi
To loosen the harness on the CabrioFix depress the button on the tensioner housing unit and pull both harness straps toward you together as instructed in the User Manual.
If this is not working it will need to come in for inspection and repair required. If you're in the UK and the carseat is under 24 months old please return to your retailer with proof of purchase for them to send to our engineers for inspection / repair under warranty terms and conditions. If you're in the UK and it is over 24 months old or you no longer have proof of purchase you can book in with the customer care team directly on 01284 413 141 Mon-Thur 08:30-17:30 / Fri 08:30-16:30 (Excluding Bank Holidays) Standard cost is 39.99GBP which does include courier collection and delivery. if you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the Contact Us tab on the right side of the screen for your enquiry to be sent through to the customer care team in your country who can assist.
Oct 08, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Ive pushed button and straps on my maxi cosy cabrio car seat will not loosen, help??
Hi
When you press the silver / grey button at the front of the carseat you should pull both harness straps at the same time and it should loosen the harness. If this is not happening the carseat needs to be inspected. Please contact your retailer with proof of purchase if it is under 12 months old. Alternatively please let us know what country you're in and we can put you in touch with the correct customer care team to assist.
Jul 06, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a Cosco Juvenile car seat and my husbands car. In the back seat he has seat belts that are a combination shoulder and lap strap. How do you connect the car seat so that it is secure in the back...
you take the seat belt and put the lap strap thru the back of the carseat and click in in on the oher side pull tight and carseat is secure. the shoulder strap part doesnt effect the safety of the car seat at all
Sep 12, 2009 | Baby Gear
Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Sep 10, 2009 | Baby Gear
Need Extension Straps for 2007 Maxi-Cosi infant carseat
hello boss why dont u contact the same place where u have bought the carseat earlier(4 months back).. i guess he can be very help ful to u..
Feb 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Britax Roundabout car seat thigh strap adjustments
Carseats werent made for all the extra stuff we have to put on our kids. So will have to take your little one in and out of the snow siut in the car. I have an auto start button on my keys so I can warm the car before we go out there, so I can take my little one out of his warm wear in the car. Its just a headache putting them back in it once you get to your destination.
Nov 28, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax marathon harness straps
how to make harness larger
Feb 21, 2008 | Britax Marathon
Evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Feb 17, 2008 | Evenflo Journey Premier Stroller
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
Jan 22, 2008 | Cosco Summit 22260 - Bouncing Sheep
Evenflo Generations Logo
Top Evenflo Baby Gear Experts
Barb
john h
ADMIN Canada
ADMIN Canada
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
