Question about Measuring Tools & Sensors
Easy weather station not picking up the data from my weather station
Posted by Mark Skelton on
Strnj1
    Sergeant:
  • 239 Answers
This is the quirk with these "weather stations." They're battery operated. When the temperature gets down to a certain point, the voltage output from the battery drops below the minimum required to operate it.
You lose the signal from that station. Lithium batteries help...
Posted on Mar 09, 2014
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
Bushnell 7 day wireless forecaster troubleshooting
Toward the middle or end of March 2014, Bushnell and Accuweather terminated their data sharing contract for the Weather FXi, Hunt FXi and Golf FXi internet-based weather stations. Since the forecast information is freely available on Accuweather's website, all Bushnell would have to do is fix/update the software to grab the data a different way. These were awesome weather stations when they worked and now Bushnell has decided to brick them by refusing to update the software. They have our money and now we have electronic waste paperweights to pollute the landfills. What a great business decision for them! I for one have decided to never buy any Bushnell products again and I hope everyone else who Bushnell screwed over by this decision to brick perfectly good weather stations also decides to boycott Bushnell products.
Mar 26, 2014 | Bushnell Weather Hunt FXi Forecast Station...
Base station will not load with 5 day forecast
Feb 24, 2014 | Bushnell Weather Hunt FXi Forecast Station...
I have lost the manual and software disk for my Bushnell Hunt FXI weather station. Where can I download these?
Don't bother. Toward the middle or end of March 2014, Bushnell and Accuweather terminated their data sharing contract for the Weather FXi, Hunt FXi and Golf FXi internet-based weather stations. Since the forecast information is freely available on Accuweather's website, all Bushnell would have to do is fix/update the software to grab the data a different way. These were awesome weather stations when they worked and now Bushnell has decided to brick them by refusing to update the software. They have our money and now we have electronic waste paperweights to pollute the landfills. What a great business decision for them! I for one have decided to never buy any Bushnell products again and I hope everyone else who Bushnell screwed over by this decision to brick perfectly good weather stations also decides to boycott Bushnell products.
May 28, 2013 | Bushnell Weather Hunt FXi Forecast Station...
Need to download bushnell weather fxi CD
Feb 16, 2013 | Bushnell Weather Hunt FXi Forecast Station...
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
What does the Davis wireless weather envoy Map do?
The Davis wireless weather envoy can takedata from a wireless Vantage Pro2 integrated sensor suite or wirelessTemperature/Humidity, or Leaf Wetness & Soil Moisture/Temperature stations,and posts the information to your computer. If you use it with a WeatherLink datalogger and software package it can store data from outdoor sensors. Hope thishelps.
Jul 17, 2012 | Davis Instruments Davis Wireless Weather...
Is it possible to recommend me a on a weather station software??
I can recommend you on Weatherlink Software but the market offers another good programs.'Weatherlink Software for Weather Stations' -Is a good weather monitoring, connect the Perception II, Weather Wizard III or Weather Monitor II to your personal computer. WeatherLink data logger stores data-even when your computer is not running-until it is transferred to your computer. You can use WeatherLink software to create graphs, calculate totals and averages, generate summaries, analyze trends, and more- all with your own weather database. Data may be exported to most popular databases.
Aug 12, 2010 | Bushnell Measuring Tools & Sensors
Measuring Tools & Sensors Logo
410 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
