Hello! If the battery has been disconnected and the radio was not changed the system will clear on its own...It takes 1 hour, with the radio on, to reset itself...However, here is the procedure...
1. Turn on the Radio... "Safe" will appear in the display...
2. After 3 seconds, the number "1000" will appear in the display....
3.
Use the radio station preset buttons 1 to 4 to enter the code number...
Use
preset button 1 to enter the first digit in the code number. Use button
2 to enter the second digit, etc... The value range for each of the 4
digits is "0-9"... The digit will increase by 1 each time you tap the
preset button... The number returns to "0" after 9"...
4. After you
finish entering the code, press the right side (">") of the SEEK
button for longer than 2 seconds until you hear an audible signal...
5.
If you have entered the code number correctly, "LSM" wlll appear in the
display...
If you entered a wrong code number, "SAFE" will appear in the display... Initially it'll flash, then stay on...
You can repeat the procedure again one time...If
the wrong code number is entered again, the unit will be disabled for 1 hour... Leave the unit on and the key in the ignition...
Guru......Saailer I’m happy to help further over the phone at
https://www.6ya.com/expert/david_6df67de3b14de867
