Question about Spalding Basketball
Manual for 54 inch polycarbonate backboard - Spalding Basketball
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
What causes "toner not recognized" message?
Printers are programmed to reject non-genuine ink tanks and toner cartridges.
Some of them are also designed/programmed to stop working altogether if you fit an aftermarket product and you will have to get a new printer. Most likely you have one of those.
Never use non genuine products. You can try and pull the new genuine OEM toner cartridge out and refit it and see if the machine will reset and recognise it. If not I don't think you are going to get it printing again and you will be up for a new printer..
Follow some of the trouble shooting procedures in the user manual and if none of these work you are probably done with that printer.
Jan 04, 2016 | Goalsetter X554 54 Inch Glass Extreme In...
We got the top pole back to front..how to separate the poles ?
As silly and bizarre as this may sound... just take the pole and raise it to shoulder height and throw onto the grass at an angle. It may take a few attempts but the pole WILL come apart. I know you think I'm crazy ...but it does work. It's almost like a Chinese finger trap.
Jul 24, 2015 | Goalsetter GS60 60 Inch Glass Wall Mount...
What the Problem
You need to give us a better picture and description of your problem. It looks like you are working with a basketball goal that is laying down on the ground. Do you really mean only the "Net," or are you using the word net to mean the whole backboard mechanism? Are you talking about hooking the strings of the net to the orange "hoop?"
Is this the first time you have tried to raise it, or has something changed after you have used it successfully for awhile? Is this new and you put it together yourself? If so, you probably made a mistake. Review the instructions, or ask a mechanical friend to look at it.
Often the answer is easy - its asking the right question that is the hard part! Hopefully you can understand that you have not yet asked us the right question.
May 26, 2013 | Basketball
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Mar 16, 2013 | Basketball
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Basketball Logo
234 people viewed this question
Top Spalding Basketball Experts
Anon
Tom Chichester
Are you a Spalding Basketball Expert? Answer questions, earn points and help others
