For the brush to stop spinning, this suggests the belt has snapped or come off the motor. The little black rubber piece which fell out may be the remains of a chewed up belt. I suggest checking the belt is where it should be, may be hidden under a removable cover, and that it is stretched round the motor spindle.
Please make sure that the plastic pieces that holds the outer/inner bags on the vacuum are attached properly. Push the outer (permanent) bag down against the vacuum. It will go over a black lip. Put first piece of the bag dock on..make sure it is behind that lip also. When you reattach the second piece to the dock, this will tighten the docking system. It will keep the outer bag on and keep the inner (disposable) bag in place so that it is catching the dirt...not the outer bag.
Remove side cover below is a small piece of red plastic with screw attatched check to make sure belt is not broken or for some reason come off. Could be hair build up or your vaccum cleaner is not picking up enough dirt and debri causing it to clog. Steve
the big paper fiter attaches to the underside of the big black top piece of vacuum. there is a round plate and a nut you scew on to hold it. a foam rubber filter fits over it.
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber or see small pieces of black rubber? Look in your manual for replacing power head/brushes belt! With the unit off , try turning the brushes by hand and clean them off of debris, etc., as well while there. See if you feel some tension or hear the motor moving inside, indication that the belt is still attrached and if it doesn't seem to have any resistance and you see small pieces of rubber and /or, the band/belt may have just broke from normal usage. WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square
hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
if theres only three wires , green, black and white then the green wire is a ground which goes to an exposed metal exterior screw on the pump. It doesent matter which way the black and white go, it will work either way but if when you try to attatch the connectors theyre harder to attatch one than the other then switch it to the most easier way to attatch. Make sure to connect the green ground wire, it is very important and always try plug the shampooer into the bathroom where the ground fault plug is- its an added level of security in case theres a ground fault.
