Aug 29, 2017 | Heating & Cooling
Dec 07, 2012 | Craftsman 16" Electric Chainsaw Chain Saw...
Oct 06, 2012 | Bryant /murray Bj2200 Main Circuit Breaker...
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
It works just like a normal circuit breaker with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker.
So what is wired to the shunt that is not letting the breaker reset?
Read more: http://wiki.answers.com/Q/How_does_a_shunt_trip_breaker_work#ixzz1EXNCP5r0
Feb 20, 2011 | Square D Qob120 Circuit Breaker With Shunt...
Feb 14, 2011 | Dryers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
May 16, 2010 | Kenmore 13593 Stainless Steel Built-in...
Jun 14, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
Jan 25, 2009 | RTO Cutler-hammergd3100 100amp 3pole...
29 people viewed this question
