Panasonic TH-42PZ700U 42 in. Plasma Television Logo
A
Anonymous Posted on Mar 08, 2014
10 blinks put in new powr supply - Panasonic TH-42PZ700U 42 in. Plasma Television
New power supply don't work
New Power Supply installed, computer won't boot up ...
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
May 22, 2013 - 6 posts - ‎2 authors
I have recently received my new power supply, i was very excited for it and just finished installing it. ... those were already 100$ on both the powre supplies, i don't want to .... Do you have another computer around that works?
New power supply now computer won't turn on [Solved ...
Jan 22, 2014 - 3 posts - ‎2 authors
Bought a new 500W power supply to replace the one of the same wattage. I wanted to ... This should turn the PSU on and the fans should work.
pc not booting after installing new power supply (pictures ...
2answers
Put new 125V 4A fuse in and it keeps blowing it out.
Something on the powre supply board has shorted out.
Repair the board or buy a new one.
Cartridge error
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking......
Good Luck!!!!!
Dell Latitude D810. I bought a new powr supply from dell. I keep getting a popup saying that it cannot determine the AC power adapter. Also, my battery is dead.
You will get this error when you get a newer power supply than what was originally design for the Latitude, also when the unit came from a 3rd party supplier not on Dell's OEM supplier list, and your battery will some what solve this upon getting a new one.
As for the pop up itself, no harm. Just a nusance. You should be able to turn this off in the Administrator file and select services. Look for power management and deselect monitor AC power.
Good Luck.
C2Solutions
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Ware cani put my powr wire in the firer wall for
Follow the main wiring harness from the engine to the point in the firewall where it enters the passenger compartment,
Run amp wire ( usually zero guage very very flexible wire ) through this same hole.
HOWEVER if you don't have enough room you can drill a new hole BUT use a rubber grommet otherwise the metal will chaff the wire and will melt your wiring.
Lense stays open, when i press power light blinks and nothing happens.
help me
my lens is open and extended and when i power it up the light blinks and makes a noise and powrs back down
1helpful
2answers
Pc will not power up
Swimmie
to chack ur power supply open all connector from system board and drive. then conect power cable with powr supply and powr on ur wall outlet switch. than take mother board connector find green color wire and take a small pice of coper wire and connect it with this green wire and a black wire. then chack smps fan is moveing or not if it's moveing then ur smps OK.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
