Question about Hitachi P42H401 42 in. Plasma HDTV
Hi, I have a Hitachi Plasma P42H401a No Power at all my niece plugged i the Wii console while power was on now it will not Power up at all, Could it be the Main Digital Board or the Power Supply Board? I all ready tried this procedure it did not work. 1. Press the POWER SWITCH (ON/OFF SWITCH) once.2. If there is still no power, wait 30 seconds and press the POWER SWITCH again.3. If there is still no power, unplug the power cord from the wall. Wait 30 seconds and plug the power cord back in. Press the POWER SWITCH again. Thank you!
Posted by William Bias on
Opal Dunn John Finnegan
    New Friend:
Does your plug have a reset on it?
Posted on Mar 09, 2014
  • William Bias
    William Bias Mar 10, 2014
    No!
  • William Bias
    No! But I am going to check the power supply Thank You!
rtiger54
I have an element flat panel and the power went out. I opened the back and checked the power board for burnt components and blown capacitors. I found a blown cap. I removed the board, unsoldered the bad cap and soldered the replacement to the board, plugged everything in and voila power restored!
Posted on Mar 12, 2014
5 Related Answers
Anonymous
  • 186 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Posted on Apr 29, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Hitachi 50"plasma model 401 wont power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Another possibility is a close lightning strike and the factory surge protection is not up to preventing damage from those.
Posted on Mar 30, 2009
Anonymous
SOURCE: intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Posted on Nov 13, 2009
Chi Chu
  • 8457 Answers
SOURCE: Hitachi Plasma 50 inch H4011 series just went off
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Posted on Feb 21, 2010
Testimonial: "Thanks. It must be pretty easy if a teenage boy can do it. "
Anonymous
  • 33 Answers
SOURCE: I have a Hitachi P50H401 plasma TV ,when you hit
unplug the unit for a while like one hour or so.
Posted on Sep 03, 2010
My Hitachi tv model p42h401a will not turn on. The "standby"light is not on either. I have checked the power supply and that is working.
Have you opened the actual TV and checked the power supply board inside? Because that is what it is. You need a new one.
May 09, 2011 | Hitachi 42HDT79 42 in. Plasma Television
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    Hitachi power suply p42h401a is damage
    I have a working power supply for your TV if you're interested.
    Let me know if you require further assistance.
    Jul 04, 2010 | Hitachi 42HDT79 42 in. Plasma Television
    P42h401a clicking and resetting whenever turned off after surge
    Hi: This could be caused by a surge that may of damaged the Power supply unit. Replacing the power supply board is a good option at this point, you did not mention if you are able to watch the set, but if so and this is happening when you turn off the set the the system control board which controls the power on/off of the power supply may also of been affected.
    Apr 21, 2010 | Hitachi 42HDT79 42 in. Plasma Television
    Wii console will not power on. is there anyway to
    Hi there, you could try the following:
    1. Try unplugging Wii from the power for a full 2 minutes, plug back in and power up and test (This resets the Power Adapter).
    2. If this does not resolve it then it may need to be repaired so contact Nintendo here.
    Please see here for for information on Power issues with the Wii.
    Cheers
    Apr 03, 2010 | Nintendo Wii Console
    Hitachi brand and model
    NO...mine broke after just two years $800 to fix
    Dec 25, 2008 | Hitachi 42HDT79 42 in. Plasma Television
    Wii Poer voltage Damage
    The problem is that the voltage in NZ is different (higher) than that of the USA, and the power adapter (gray box that plugs into the wall) has blown. Replace the power adapter and use a voltage converter that lowers the power to 115 (or 110/120) volts, and you should be good to go. ;)
    Jan 28, 2008 | Nintendo Wii Console
    Hitachi P42H401 42 in. Plasma HDTV Logo
    466 people viewed this question
    Top Hitachi Televison & Video Experts
    matt martin
    matt martin
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
