2001 Ford Focus Logo
D
Doug Smith Posted on Mar 09, 2014
When stopped gears sometime grind when shifting into 1st gear(2001 Ford Focus)
Is the 5 spd manual transmission fully synchronized in all forward gears?
A
Anonymous
Then the clutch is not releasing properly & the continual
grinding will wear the gear teeth & you may also have worn
syncros, that will require you to pull the trans & go thru it, as well
as do a clutch replacement
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Apr 03, 2009
SOURCE: Difficulty shifting 2000 Ford Explorer 5 spd. manual transmission
have you checked to make sure your clutch fluid is topped up? low hydrolic fluid can sometimes cause this.
Anonymous
  • 57 Answers
  • Posted on Aug 26, 2009
SOURCE: 06 ford focus 5spd. no 1st, 3rd, or 5th gear.
It sound like the gear linkage isn,t set up right, you wouldn,t always be able to engage a gear unless you rocked the car.
Anonymous
  • 54 Answers
  • Posted on Oct 27, 2009
SOURCE: Ford Escape Automatic Only Goes Into 1st Gear Manually
it sound like you have a vacum leak or your shifter cable may need adjusted
Anonymous
  • 80 Answers
  • Posted on Jul 07, 2010
SOURCE: I have a 2001 Ford Mustang, v6 3.8 5 speed manual
Hi Bobby, I found this bulletin on I believe the problem you are talking about. Hopes this helps ya put.. Cobra.. Please read..
FORD: 1999-2004 Mustang
ISSUE: Some 1999-2004 Mustang vehicles equipped with a T5, T45 or TR3650 manual transmission, may exhibit a hard to shift condition into first or reverse gears from a stop. This may be due to an incomplete disengagement of the clutch (lack of clutch pedal reserve).
ACTION: Refer to the following Service Procedure. It may be necessary to adjust the clutch pedal down-stop and the clutch pedal shaft nut to gain full pedal travel.
SERVICE PROCEDURE
  1. Lift up on the clutch pedal to reset it.
  2. Measure the clutch reserve per the instructions listed in the Workshop Manual Section 308-00, Diagnosis and Testing, Manual Transmission and Clutch. NOTE: THE MINIMUM RESERVE NEEDED FOR GT, LX AND 1999-2001 COBRA IS 19 MM (3/4").
    1. If the measurement obtained is larger than these values, DO NOT CONTINUE WITH THIS TSB. Follow normal Workshop Manual diagnostics listed in Section 308-03.
    2. If the measurement obtained is less than these values, make sure that the floor mat or excessive material under the carpet is not preventing the pedal from reaching its full travel. Correct any obstruction, if the condition is corrected return the vehicle to the customer. If the condition is not corrected proceed to Step 3.
  3. Visually examine the pedal down-stop to see if it is preventing the pedal from reaching its full travel to the carpet. Correct if necessary by removing the rubber pad on the down-stop. If the condition is corrected return the vehicle to the customer. If the condition is not corrected proceed to Step 4.
  4. Additional travel can be obtained by loosening the clutch pedal shaft nut and adjusting as needed per Section 308-00 of the Workshop Manual. If the condition is corrected return the vehicle to the customer. If the condition is not corrected proceed to Step 5.
  5. If inadequate reserve is still present refer to Workshop Manual Section 308-00 for clutch pressure plate and disc diagnostics
Anonymous
  • 318 Answers
  • Posted on Nov 26, 2012
SOURCE: 1986 ford ranger transmission not going into 1st or 2nd gear
If third, forth, and fifth work OK then there could be a selector problem. Does the gear stick go into the correct position? If so then selector and or other internal problem which will require removal
1helpful
2answers
My ford bantam 1300 doesn't want to select 3rd gear
this manual transmission?
seems. so
the tip of shift levers love to get worn and not allowing the shift rail forks to hit 3rd gear.
a pure simple mechanical failure and is shifter tip end parts bad, some are even made of plastic.
or
3rd gear synchro- ring is super worn out and the main clutch drags. (seen it and fixed them)
if clutch has master cylinder is the fluid always at top line or drops in time every weak.
1996 Ford Ranger xlt manual transmission can"t shift into 3rd and 4th gear
If it grinds when trying to shift, it is the synchronizers. Rebuild. If it pops out of gear. there is a plastic part at the top of the transmission that wears out. It fits around the ball of the shifter. It is two pieces. You'll have to remove the floor plate and pull it up to access the bolts to remove the shifter and replace those plastic pieces.
Ford festiva transmission
You have a manual transmission. The synchronizers are bad. Probably a couple of bad bearings also. Get a manual and buy the parts. Save yourself atleast a $1000 labor from a garage.
My 1999 Chevy Silverado 1500 Z71 makes a clunking noise and feels like it got rear ended if I drive it for an hour or so non stop. It seems to be when it shifts from 1st to 2nd gear. I had the ******...
No one can tell you what it is.This is the operating characteristic of your transmission and customer do object to the noise or clunk and dealer discourage the repair. This is TSB 03-07-29-004G. Let me give you a partial copy. INFORMATION
Bulletin No.: 03-07-29-004G
Date: December 15, 2010
Subject: Manual Transmission Operating Characteristics
Cold Operation
Manual transmission operation will be affected by temperature because the transmission fluid will be thicker when cold. The thicker fluid will increase the amount of force needed to shift the transmission when cold. The likelihood of gear clash will also increase due to the greater time needed for the synchronizer assembly to perform its function. Therefore when the transmission is cold, or before it has reached operating temperature, quick, hard shifts should be avoided to prevent damage to the transmission.
Backlash
Backlash noise is created when changing engine or driveline loading. This can occur when accelerating from a stop, coming to a stop, or applying and releasing the throttle (loading and unloading the driveline). This will vary based on vehicle type, build variations, driver input, vehicle loading, etc. and is created from the necessary clearance between all of the mating gears in the transmission, axle(s) and transfer case (if equipped).
Shift Effort
Shift effort will vary among different style transmissions and synchronizer designs. Usually the more heavy duty the transmission, the higher the shift effort because of the increased mass of the components. Shift effort can also be higher in cold weather because the fluid will be thicker. Medium duty transmissions will not shift as quickly as a Corvette transmission. To reduce shift effort, do not attempt to rush the shift - allow the synchronizers to work as designed. Shifting harder will only increase the chance of rushing past the synchronizer leading to grinding while shifting.
Non-Synchronized Gears
Some light duty truck transmissions in 1st gear (creeper-gear) and reverse gears in various transmissions, along with all gears in some medium duty transmissions, may be non-synchronized. This means there is not a mechanism to match input and output shaft speeds to allow for a smooth shift. This function is left up to the driver. This can be noticed if a shift into 1st or reverse is attempted while the vehicle is rolling or before the input shaft stops rotating leading to a gear grind. The grinding can be reduced by coming to a complete stop and pausing for a moment before shifting into the 1st or reverse gear. Some slight grinding can be expected. In medium duty non-synchronized transmissions, the driver must match input shaft (engine) speed to output shaft (driveshaft) speed with every shift. This can be accomplished by double clutching, or by using other methods. If the driver is not able to perform this function properly, there will be gear grinding with each improperly completed shift. Driver training may be required to correct this condition. Clutch brakes are used in medium duty non-synchronized transmissions to allow a shift into gear at a stop. The clutch brake is used to stop the input shaft from spinning, allowing a shift into gear at a stop without grinding. The clutch brake is activated by pressing the clutch pedal all the way to the floor. When the clutch brake is used, it is possible to have a blocked shift with the vehicle stationary. If this occurs, engage the clutch slightly to rotate the input gear to allow the shift. The clutch brake is intended to only be used while at a stop. Care must be taken to not activate the clutch brake while shifting between gears. This could lead to excessive grinding or a blocked or missed shift.
1helpful
2answers
Ford fiesta 2003 reverse gear sound...
if you are only having the issue in reverse that would make me lean more towards the transmission having an issue than the clutch.
1helpful
91 mazda protege, grinding lower gears?
More than likely the synchronizers are going out,they allow you to move from gear to gear without damaging transmission.
1helpful
2nd gear crunch
first of all you shouldn't be reving that high to change gears. that's too high. secondly if it's grinding only during the change from 1st to 2nd gear you may have a problem with the gears not being aligned anymore...ie synchronizers worn out, bearings worn out, etc. take to reputable transmission shop to get it diagnosed and repaired. it sounds like the synchronizers are a problem there. and you may have metal in your fluid now that it's been grinding which will affect the rest of the transmission. if you are speed shifting as in racing, you are not doing your transmission any good. you probably don't have a transmission built to do that if it's the original factory tranny... meaning you did a major NO NO to your tranny and are tearing it up speed shifting when it isn't built for racing.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
