SOURCE: KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
SOURCE: attachments do not reach the bottom of bowl when mixing
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
This is the FAQ from the Kitchen Aid website. It explains very well how to make the necessary adjustments under the question: My flat beater, wire whip and dough hook are scraping against the bottom of the bowl when I use my mixer. How can I fix this?
SOURCE: Paddle is rubbing the bottom of the mixing bowl
It is going to low down. the adjustment should at the back of the unit.
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
SOURCE: Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
