Question about LG HBS-700 Bluetooth Headset
Vibration ane blinking red light
While listening to music the unit began vibrating and blinking red I have powered off and it keeps doing it when I put it on the charger the light won't come on what's going on please help Thanks
Posted by Dylan Kincade on
CJ Brown
    New Friend:
  • 4 Answers
When a call on your phone comes in i will vibrate, flashes red when battery is low. The light will also be red when its charging. It will turn off when its charged.
Posted on Mar 10, 2014
Blinking red light
How many times this power/standby light blinks? It is fault indication, and are fault codes. If you wish to get some details about these codes, try this link. http://electronicshelponline.blogspot.com
Dec 22, 2013 | Denon AVR-1513
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Normally when i charge my cameras battery a red light will turn on to let me know its charging and will stay on until it is fully charged but whn i went to charge my battery yesterday the red light began...
Charge your battery with an external power supply or a car battery charger for like 10 seconds (1 ampere will do the trick) by connecting the + and the - of the battery to the + and - of the power supply.
Now insert the battery in your normal charger. ìf it will still not charge do it again for 10 seconds.
Dec 27, 2009 | Casio Exilim EXZ75 Digital Camera
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Oct 03, 2009 | Invacare Pronto M51 Power Wheelchair
Htc p 3300
dismiss all messages/notifications (for NO Blinking amber light), disable vibrate
attach the original charger, keep phone on a flat surface, find optimum position where the amber light is continuous.
repeat same if you answer any calls or move the phone
May 14, 2009 | HTC P3300 Smartphone
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
My samsung juke u470 (navy) became 'inoperatable' since yesterday...
try having the phone's firmware reflash online , you can go to www.topsony.com , or take the phone to a service center close to you and have it done.
Mar 23, 2008 | Cell Phones
LG HBS-700 Bluetooth Headset Logo
435 people viewed this question
Top LG Radio Communications Experts
Anthony Ward
Anthony Ward
Brandon Hunter
bill_bertham
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
