Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Oven preheat times
Oven takes over 30-45 minutes to preheat to 425. Seems that the lower the temp the shorter time it takes to preheat but it still takes forever.
  • 2 more comments
  • Constance E. Hecht Mar 10, 2014
    I wish I had better news. My oven has taken forever to preheat even when brand new. I had the repairman out and he said that was normal. It might help if you started at 350 and when it reaches that then increase to 425. The repairman told me it had something to do with the new heating "parts". They don't just stay on the entire time, but come on and go off during the use of the oven.
  • Karyn Hradsky
    Karyn Hradsky Mar 11, 2014
    Thanks Constance for your reply. I really appreciate it!
  • toriless Mar 11, 2014
    Gte a real reapirman =not someone sent you coupon. There's reson they are sending coupons. A good repair person has no need to offer everyone half off. No oven should take mnore then 10 minutes to reach full tempreature. Yes, it makes sense tht heating to 350 take less time. It can onlt put out so much heat per minute. Is this the loser on your "repair" warrantee? Probably, he just trying to minimize his cost. If he makes excuses he gets paid to do nothing. This is WHY those extended warrantees are useless. They send out worhtles bums who makes excuses and instead of doing their jobs liek aral reapirman. Constance E. Hecht was ripped-off by a con arrtist. PERIOD. He scammed you!
    I need a spell checker!
    Sergeant:
  • 290 Answers
It gas not electric. There is NO hidden element. It a bad sensor.
Posted on Mar 11, 2014
5 Suggested Answers
Anonymous
  • 290 Answers
SOURCE: Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Posted on Oct 29, 2007
douglas smith
  • 1462 Answers
SOURCE: kenmore 790.96124
times quoted are normal
Posted on Jun 16, 2007
SolutionGuy
Tracy Farrell
  • 331 Answers
SOURCE: Oven won't heat accurately
Brad, your right on track. But I'd look toward the sensor first (The computer only does what the sensor tells it to do). I'll need the model number to find part numbers to help you further. The model number is on a sticker located on the oven body behind the lower drawer. It'll start with 3 digits then a decimal point the more digits (xxx.xxxxxxxx).
Posted on Sep 27, 2007
Anonymous
  • 126 Answers
SOURCE: preheat issue with a new kenmore electric range
some of the newer ranges only pre-heat using one element. this gives them a better energy saving rating
Posted on Nov 23, 2007
blueextc3221
blueextc3221
  • 15935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Jul 25, 2008 | Kitchen Ranges
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
291 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
