The serger got jammed and I fixed everything except the cutter. It doesn't seem to cut and I tried replacing the blade but that didn't do it. It seems like it is in the wrong place however if I move it, it hits stuff or jams the machine. Please help
SOURCE: need a munual for White Speedylock 1300 DE serger
http://sewusa.com/Threading_Diagrams/Threading_Pages/White_Sewing_Machine_Threading/White_1600_Speedylock_Threading_Diagram.htm
If this isn't helpful, email me and I will scan my manual.
SOURCE: needles break and machine jams
TIPS FOR SUCCESSFUL SERGING WITH WHITE SERGERS
http://www.whitesewing.com/PDFs/Serger_Tips.pdf
SOURCE: White Speedylock 1500 Serger Manual
I have a 1500 with a manual. I could copy the manual and send it to you. Email me at [email protected]
SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
SOURCE: Blades need replacing.
If there is a joann fabrics store nearby, they have them. I think you can also order them online:
www.joann.com
Since the machine jammed, there is a chance that the timing has been thrown off on your serger. You may need to have it recalibrated. That happened to my machine. I hit a thick spot when serging denim, and bam!, it refused to work after that. I don't know how to adjust the timing, and honestly, I wouldn't pay more than $80 to have it repaired. More than that is just a rip-off. I wish you good luck!
