The movie camera when turned on and trying to shoot has multi vertical colored lines through lcd viewer. I cannot take any movies or pictures.
The camera has been used about a total of one hour when it started doing this, the camera shop wants to charge me up to $150.00 to fix it, if they can. I am not high on the help that I received from JVC help line either (It is a joke) no help at all. It is probably a minor adjustment, I hope someone can help me.
Thanks
Bill Mack
Greendale, Wi
SOURCE: Image being displayed is all colored vertical lines
I had this problem a lot on Labtops. The problem is that it has been unliquifed in the screen. This means that the screen has been damaged or has got really hot. Also its has been on for along time. LCDs go bad real quick and can be a hassle when you need the infomation in the thing and have no display. When I had this problem on my labtop, I used the external bay to use another monitor so I can work on it. So I say that nothing can be done to fix it. The only way to see your stuff on there is to use the video out on the recorder and try to check your stuff. That multicolor lines you saw is becoming major right now in LCD displays. I hope this solves your problem.
SOURCE: Split screen and blurred vertical lines in view finder and LCD
Elakkis, I am sorry you are having a problem with your JVC camcorder. Your camera more than likely has a defective CCD imager which is being replaced by JVC factory service at no charge because of a problem with the Sony CCD chip being used. Call JVC and arrange to send the camera to them. Hope this helps you! Joe Weibel Custom Electronics (customelectronics.org)
