Microtek 710S 17" Flat Panel LCD Monitor Logo
A
Anonymous Posted on Mar 07, 2014
No sound audio device not working
8helpful
2answers
Sound and Audio device in my compaq laptop is not working at all. When I checked in the control under sound and audio device icon, no sound and audio device is highlighted. Please suggest, how to solve it.
My laptop has no sound
Please add more details but I can suggest,
Control Panel > Sounds, Speech and Audio Devices > Sounds and Audio Devices, and try to change your default device to Realtek HD Audio Output. If that doesn't work restart your computer (if your audio only stopped working today)
2answers
My speakers won't work we tried everything
do you have the audio drivers installed on your computer.go to control panel,sound,speech and audio devices and then click on sounds and audio devices.it should open up another window sound and audio devices properties.click on audio and check default audio device.should have some devices e.g realtekAC97.if its not there, google it to install and it should work.if this doesnt work please let me knoa.
Button for sound on my laptop dont work
The most likely causes for this is:
External Speakers not turned on. Turn them on...
Driver for the sound device isn't installed: If you see the little speaker icon down the bottom right hand corner of your screen (near the clock), your sound card device driver is working well.
If it is not visable, the sound card device driver may or may not be working. Go into the start button, select settings (if available), then control panel, Sounds and Audio Devices.
Select the Audio tab Ensure that you have a 'default device' set.
If you get any errors when going into the sound and audio devices tab stating that you have no audio devices installed, then its most likely a driver issue. In this case, refer to your local computer shop to have the audio drivers installed.
Driver for the keyboard sound function not installed or not running. Solution: Reboot then test it. Reinstall the driver, test it.
1helpful
2answers
Sound card not detected
ask to expert by calling 18002044427 toll-free number and get quick solution regarding your query...
1helpful
3answers
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
2helpful
4answers
Sound and audio devices problem
all the options in sound and audio device properties are in active no sound is heard
3answers
The yello esclamation mark signifys you need up dated drivers then it will go again.
Top Microtek Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
