LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Mar 07, 2014
How to shut lgx25971st down to defrost - LG LFX25971ST Bottom Freezer French Door Refrigerator
Compressor shuting down
Either the thermostat is prematurely shutting down the compressor or the latter is overheating and the clixon is shutting it down.
The defrost timer also will shut down the compressor and all fans but that is only once every 10 hours or so to defrost unit. In about t10 15 minutes the timer will turn the compressor back on.
2helpful
2answers
Defrost problem - Follow-up Question?
Replace the defrost thermostat. They are cheap and 90% of the time will be the problem.
Freezer only shuts off when in defrost mode
you will probably have to change the controler
Defrost Timer or the Defrost T-Stat?? Also Model # VCSB480SS06
no defrost timer runs through control most common issue is limiter
Freezer not auto-defrosting; replaced defrosting coils. What controls them?
Hi welcome to fix-ya. The defrost is started when white sensor located top of coil left side. That tell the motherboard to defrost. When done the same sensor shuts down defrost. The defrost termintor that is wired in line with heater is only for safety. I hope this helps.
Build up of frost in freezer and fridge not getting cold. Defrosted everything over night and plugged back in. Both freezer and fridge working now. Advanced defrost timer manually and fridge shut down. How...
Frost accumulating on the freezer is an indication of a defrost failure. It likely has one of three failures.
1 Bad defrost heater.
2 Bad defrost termination switch.
3 Failed defrost timer
In order to confirm, which has gone wrong manually advance this refrigerator into a defrost cycle. This is done by doing the following in order:
1. Disconnect power to the unit for at least 30 seconds
2. Turn the thermostat to off position (leave it off)
3. Reconnect power
In a few minutes, if you can hear a hissing noise in the freezer or see a red glow from the heater, it
indicates the timer is not advancing and will need to be replaced.
If nothing happens when the defrost timer is manually advanced, some voltage and resistance checks will need to be made. I recommend having a technician make these checks.
Hope this helps.
Shane
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
Hi and welcome to FixYa, I am Kelly.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Hi My fridge has suddenly stopped cooling. However the compressor is working. I have a single door samsung. It was not getting defrosted so we switched off the power and let the ice melt however my maid...
It is possible that the auto defrost timer is faulty and must be checked.Once the compresoor has been shut down and restarted the timer should shut down the compressor and defrost connecting the heaters.Hence check timer heater and also the thermostat(it must shut down at low setting).
1helpful
Refrige and freezer do not get cold. Freezer is all iced up.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Compressor on sxd20tw wont shut off. just cleaned
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
