Question about Kodak EASYSHARE 5100 All-In-One Printer
Flashing red "check ink" lights and nothing is wrong with ink
I printed two pages and it suddenly had its two "check color/black ink" lights flash red and I cant find a reason for it. I can't print, I can't do maintainance, and I do works. I turn it on and it does this and i press power again and it flashes orange next to power button and i can't do anything but unplug the printer. Holding down power does nothing as well. Please help
Posted by zspring1 on
Jonathan Larson
  • 130 Answers
Is there a resume button on the printer? If so press this, often printers will allow you to bypass a low ink message and print for a while longer.
Posted on Jun 12, 2009
I have an hp deskjet 940c. the colored ink is out but there is plenty of black ink however the ink light is flashing and it wont print. do I need to replace the colored ink in order to print something or...
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to
BW and not color in the configuration menu. That should permit you to print in BW only.
Mar 22, 2011 | HP DeskJet 940c InkJet Printer
Can I print if I do not have a color cartridge? I have a new black cartridge and recycled the empty color cartridge without replacing it. Now I get a flashing red light indicating I need ink and nothing...
Yes, go to print properties and find the print in gray scale and it will print in black only. WHen you open the print window. Click on preferences and then look for the color tab. Click on the "print in grayscale" box.
Brian
Mar 01, 2010 | HP DeskJet 940c InkJet Printer
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Problems replacing ink cartridges in epson 1000 ics
Turn off printer, unplug it from power supply.
Replug and turn it back on
Tilt scanner so that you can see the printhead, press menu and select change cartridge, press copy button.
Feb 24, 2008 | Epson 1000 ICS All-In-One InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
317 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
