Compaq IJ700 4094-CP1 Color Inkjet Printer Parallel Logo
A
Anonymous Posted on Mar 07, 2014
Prints test page but nothing else - Compaq IJ700 4094-CP1 Color Inkjet Printer Parallel
1helpful
Ink printing problem
Sounds like you already know the answer to that question ;(
Printers today are generally disposable due to the high cost of replacement parts and the cheapness of a new unit. I had a similar problem and replacement was the cheapest alternative.
My lexmark x2600 keeps telling me i need to realign the cartridge but nothing is really wrong.. wont let me print anything but alignment test pages. How do i fix this
One of the utilities included with the Lexmark software will print a "test" page.
Then, you view the test page, and enter some numbers into the utility.
The utility uses those numbers to (ectronically) align the print-heads.
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Color image or text will print but nothing black will
Please reseat your blackcartrige of the Printer , if it still does not work , get it replaced.
Hope this Help.
Cheers!!!!
2answers
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
2answers
Printing problems
plz check whether the driver is installed, go to printers on control panel and try for a test page print, if test is printed, then could be ur software is looking that printer.
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Top Compaq Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
