Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
I can't move my Troy-Bilt tiller unless it's running.
Does anyone else have this problem?  We can't move it into the garage unless it's running. The tires are locked and it has to be dragged.
Posted by irishkatz1 on
Anonymous
  • 22 Answers
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Posted on Jun 14, 2009
Why does my troy bilt super bronco will not roll unless it is running
-You have to shift to Neutral before it can roll free.
Good luck
Mai
Aug 29, 2014 | Troy-Bilt Super Bronco 16-Inch 208cc...
Pony size Troy-Bilt 30 years old\r\nQuestion; Can motor be replaced?
Yes but unless you purchase a engine with the two shafts, one for forward and one for reverse, you will lose your reverse. If you don't mind not having a reverse just go to a nearby Harbor Freight store or order on line a Greyhound 6.5 HP engine. these are Honda clones and run great they just had a sale here in Columbia Mo. and it was on sale for $99.99. I have used these on many of the Troy Bilt Horse tillers and they work great. They have metric threads and you may not be able to use your throttle cable but for the price you can't beat it.
Frank
Oct 03, 2010 | Troy-Bilt Pony Garden Tiller
Disengage wheels from transmission
Pull out the bolts that bolt the wheels to the axle,then the wheels will freewheel.
Apr 26, 2010 | Troy-Bilt Pony Garden Tiller
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
1,315 people viewed this question
Top Troy Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Troy Garden Expert? Answer questions, earn points and help others
