Hi have a nice day!
It is probably a power supply problem. Remove cover and check for a line fuse blown or any burnt component mainly at power supply area.
write a new comment
The tv have a power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Back lights invereter or power supply. look for 24vdc on the power supply which is needed for the inveeter board.
look for bad caps in the power supply.
Dell will replace it if it's less than 3 yrs old but apparently their tech support people are clueless about this and have to be told what they need to look up. The replacement is a nice gesture except if you're like me and paid >$1,000 for this more than 3 yrs ago. I have had TV's > 20 yrs and don't reacall major problems with any.
These instructions were posted on the Dell Community forum http://en.community.dell.com/forums/ " The following in and out of warranty TVs (W2600, W2306C, W2606C) with
the No Power issue must go through Technical Support to initiate the
exchange. Tell the technician to look up the following DSN document IDs
to get the details on the in and out of warranty exchange process:
- 313698 Dell-Branded TVs Out-of-Warranty Repair Procedure -
CTS/CBG/SMB/GTS-T/DOC. Tell them to scroll down to, Dell W2306C,
W2606C, or W2600 TV Replacement for a No Power Issue
- 329986 TVs (W2600, W2306C, W2606C) with No Power. New exchange procedure - TV and Home Theater - Dell Community Forum
* Dell will cover this issue, regardless of the limited warranty
status, for the W2306C, W2606C or W2600 TVs for 3 years from the
original invoice date
* Once past the 3 year date from the original invoice date, we will not exchange the TV
* Units sent as replacements for this issue should be considered in
warranty for 90 days after the replacement or for the remainder of the
limited warranty term, whichever is longer
* You will need to provide to them the following information -
TV Service tag number:
TV Order number:
Name:
Shipping address:
Phone number:
Email address:
Reason: Dell LCD TV has the No Power issue
There is no fix for the W2600. It has a power supply problem.
For sometime Dell was replacing the tv's with new ones, but don't think they are anymore. If you go to the Dell Forum and type in your tv you will see the amount of people that have had the same problem. Unbelieveable. As a matter of fact, Dell is not even making TV's anymore. Guess they gave up. They cannot be fix, cannot get the parts for it.
I have had the Dell W2600 for about 4 years. My remote for the Dell stopped working after 16 months. Since I was using cable I used the cable box remote. However, about 6 months ago a dark shadow appeared on some parts of the screen but the tv was still viewable. Shortly after, my power light would suddenly go out and then come back on after a minute or so. The problem got progressively worse until tonight it was off for most of the show I was watching and would come back on briefly. I popped the rear cover off and removed the metal shield and found most of the wires on one of the wire harness coming from the power supply board burned so badly the insulation was gone and the plastic connector assembly on the board melted. Because of the nature of modular board construction the power supply board and wire harness would need to be replaced and that doesn't necessarily mean the cause was fixed! To me this is a safety hazard. The TV is definitely out of warranty but I wouldn't expect this type of hazard problem. FYI, the parts I can read are made in China....what's new!
