Question about Sanyo SR-4911M Compact Refrigerator
Not cold @ frosts up - Sanyo SR-4911M Compact Refrigerator
When the heat pump is running in the fall, I notice frost build up the next morning. What cold cause this problem?
Heat Pumps and Refrigerators are the same unit running backwards. To get refrigeration you create heat, to get heat, you create frost. The end blower is the thing that either gives you heat or cold air depending on what setting you are choosing.
To stop the frost building up, you just need to cover that area with insulation. The frost is caused by a cold surface that is below freezing point and water vapour in the ambient air.
Nov 19, 2016 | Frost Refrigerators
Fridge isn't cold. Freezer is cold but frosting up
Is the fan in your freezer working? Make sure the door switch is pressed in when checking as it cuts the fan out when the door is open. Does it have a manual defrost timer?
May 13, 2013 | Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The bottom freezer has exceesive frost, and is not cold enough. I tried to remove the frost, it will work for about a week afterwords. Help
Really when the fridge frost very excessively there is less cold.
You have to regularly set up defrost setting if your fridge has automatic defrost.
Or your fridge has manual defrost then defrost it twice a week.
To minimize excessive frost, set the temp control setting to just mid- position.
Good luck.
Jul 01, 2011 | Amana ARB8057CSL Bottom Freezer...
In the freezer compartment, there is frost in the back. It's a side by side 19.9 without a water dispenser. The refrigerator part is not as cold as it should be but it is cold.
although most frost free freezers will hardly ever frost up,some will,(it depends on overall humidity)by frost free the makers say "food is frost free"but the inside is shinny plastic and all shinny surfaces will collect condensation and frost up.(look under the salad crisper,condensation?)it is worthwhile, about once a year,doing a complete defrost(NO sharp objects)and vacuum out all the vents/clean out any drain holes.
saves you a fortune in power.......
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not getting cold
MAKE SURE THE FANS ARE RUNNING FREEZER AND COMPRESSOR, THEN CHECK THE BACK WALL OF THE FREEZER IF ITS FROSTED UP YOU HAVE A DEFROST ISSUE. IF THE COMPRESSOR AND FANS ARE WORKING AND NO FROST IN THE FREEZER THATS NOT A GOOD THING..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore 74852 / 74854 / 74859 Top Freezer...
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Not cold enough
posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Oct 18, 2007 | Maytag MBF2256H Bottom Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Sanyo SR-4911M Compact Refrigerator Logo
50 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
David Soto
David Soto
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
