Question about Sony Handycam CCD-TRV37 Camcorder
TRV-18 won't eject - Sony Handycam CCD-TRV37 Camcorder
The disc tray on my iView 4000KR won't open. It has a disc inside that plays fine, but won't eject. This has never happened in the 18 months I've had the player.
Under each disk tray is a very small hole; this hole is for use when you experience the problem like yours.
Get a paper/money clip and straighten the wire; push the wire into this hole and your disk will open.
Regards
HCF
Jun 22, 2011 | Computers & Internet
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
DVR TRV-27 is showing error C:32:11
The problem is a rubber tape tension roller. Simply eject the tape, look inside where the tape goes. You will see a black rubber cylinder that may have a white plastic tube protruding. If you have long tweezer or a hemostat remove the plastic tube which hold the rubber tensioner in place, then remove the rubber tension cylinder. Clean the shaft of the black rubber tensioner with alcohol on a q-tip. Replace rubber tension cylinder and plastic tube.
Also, the tapes can cause the problem. This process is possible by one person, but you may need another person or have three hands. The C:31:23 is tape tension error. The tape has become stuck. Simply eject the tape. Holding the tape upside down, pull back on the tape cover release slide on the left side of the tape, now take the hemostat and push the tape release tab, located opposite of the tape cover, push this tab down and back toward the back edge of the tape. Now while holding both those release levers, take a pencil and wind the tape past the bad spot or until the tape winds freely.
I did both of these and was able to use the camera again and view all my tapes!
Good luck and QUIT SPANKING YOUR CAMERAS!!!!
May 01, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
Sony 8mm TRV 530 Camera
That icon means u have a jammed or bad 8mm tape in the unit its telling u to eject tape.
Oct 27, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
Is the memory stick of sony handy cam minidv trv-18 expandable?
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be tha same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Oct 15, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Camcorder wont eject
a loading gear may have gotten stripped. take or send it to video tech service in Sacramento. the guy there is super cool.
Jul 03, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Tape will not eject
This mceahnism is now defective and only a skilled workshop technician can do this job. If you need the service manual and parts we can help. Siva [email protected]
Jan 03, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Richard C Cohen
Richard C Cohen
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
