Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
