Question about Visioneer Office Equipment & Supplies
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other software programs.
Posted by duke on
Dave
  • 25 Answers
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Posted on Jun 27, 2014
2 Related Answers
Curtis Richner
  • 461 Answers
SOURCE: HP5550c scanner using Paperport 7.0LE - slow scanning
Have you noticed any quality difference in the scans? Sounds like it is set to scan at a higher resolution which will take longer.
Posted on Dec 19, 2008
Anonymous
SOURCE: visioneer 8100 and Vista
Are you talking about the $100 program? I don't see that as a fix. Or what download are you talking about?
Posted on Sep 09, 2009
Can you also Fax with this One Touch 8900 ?
This is only a scanner. To Fax, you will need a separate fax machine or fax modem. If both the scanner and fax machine are connected to your computer, you will be able to scan the document and then fax it from the computer. (Depending on your OS/software, this could be easy or take several steps. For Windows Vista and Windows 7, you can use Windows Fax and Scan to do both steps. (However, the program doesn't scan to PDFs.) Paperport will also send a scanned document to an installed fax option. PaperPort is part of the third-party software that came on the CD with the scanner.)
Documentation for the Visioneer OneTouch 8900 is available here: http://support.visioneer.com/products/8900/default.asp .
I hope this helps.
(There are some email-to-fax and web-to-fax options but I have not reviewed them.)
Hi, I want to use my old visioneer onetouch 7100 usb scanner with win 7, but can't find a driver. can you please help? thank you!
In this instance it looks like this is not compatible with Windows 7. However, sometimes a windows XP driver can work absolutely fine... I would just suggest to give it a try!
http://support.visioneer.com/products/7100/downloads.asp
good luck!
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Is there a driver available for the Visioneer 7100 usb?
maybe this will help.http://social.technet.microsoft.com/Forums/en-US/itprovistahardware/thread/f2d460e8-bb39-4576-86f6-4615fdb88049/
1helpful
Help me install my visioneer one touch 7100usb scanner
Here is the VIsioneer download site for your model:
Download and install the driver. The instructions are indicated on this page also.
I need driver for Visioneer Paperport 6100 Scanner
Go on line to the Visioneer web site. You can down load new drivers, manuaals and soft ware...Roy
Documate 510 won't scan due to previous Twain?
Try this link:
Note: You must uninstall your current driver and OneTouch software to install an updated driver.
https://www.xeroxscanners.com/en/en/products/DM510/drivers.asp
2answers
Visioneer 8100 and Vista
Help is here,
You have compatibility problems with visioneer and Vista, I helped a few people last week with the same problem.
I recommended them too www.cnet.com for the latest paperport download and got my Fixya button pressed.
Please remember to rate my efforts,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
3helpful
Troubleshooting Visioneer One Touch 7100 USB
Okay , You can scan once. Then close the scanner monitor controls. Then START-Programs-Paperport-Scanner Monitor. This reopens scanner Monitor for next scan. You may also have to START-Run- then type in %Temp%. Go to the One Touch folder to get your pics and delete all files before you scan another pic.
Visioneer scanner light barely moves HELP!
first u need to install proper drivers for ur . If installed then this may cause due to scanner hardware problem. This can be repaired . Go to ur scanner Provider for reparing. Thank you.
Top Visioneer Office Equipment & Supplies Experts
Ekse
scramblepad
scramblepad
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
