Question about Casio FX9750GII Graphic Calculator
My cursor is an annoying little horizontal line and when I try to add a forgotten digit into a long number it overwrites the previous number. It used to have no cursor - just blank. How to I go back t
Thank you.
Posted by bobbbb on
k24674
  • Casio Master
  • 8,081 Answers
Press [SHIFT][DEL] (INS) to toggle between INS and Overwrite. The cursor will change from a horizontal line to a vertical one.
Posted on Mar 07, 2014
  • jack
    jack Nov 14, 2018
    you are my dad thank you so much i hate the f***ing replace cursor it is the literal cancer of calculators, all hail this man
  • Aaron Partin
    Aaron Partin Apr 25, 2020
    Thank you so much. All those time when I typed long equations for chemistry, only to have to delete it all.
5 Related Answers
rho_sigma
SOURCE: casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Posted on Dec 03, 2008
Anonymous
  • 3 Answers
SOURCE: casio FX-9750G Plus won't turn on
I had the same problem too. I just bought it and I was trying to turn it on but it wouldn't though the manual said that it was supposed to automatically when the tab was pulled out. Good news: the Reset button on the back works. I pushed it for some time with the end of a toothpick and it worked.
hope it helps.
Posted on Jun 30, 2009
Anonymous
SOURCE: how do I calculate normal distribution using a
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
Posted on Feb 04, 2010
Anonymous
SOURCE: i do not know how
Hey it is. Okay, so start with a equation: say, y = -(1 |x|). Now type y = -(1 , then press the [OPTN] button, next to the shift. Next press the [NUM] button or F5. The first menu button should be Abs or absolute value. When your done it should look like this. y = -(1 Abs (x)) then graph it.
Posted on Aug 30, 2010
  • 6102 Answers
SOURCE: I have a Casio fx-9750GII,
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Posted on Jan 19, 2011
I get lots of little squares you can see the result but behind theres alot of little squares
The calculator belongs to a new generation of scientific calculators that enjoy the feature called MathPrint by TI, Natural Display by Casio, and WriteView by Sharp
When the calculator is configured to work with this Display you are shown a template as you would see on a textbook. The squares are the places where you enter the numbers. For example when you press the fraction key the calculator displays a the picture of a stacked fraction with one square on either side of the horizontal fraction bar. The square where the cursor is located and blinking appear dark. You start entering the numerator there, then you use the down arrow to move to the denominator. When fraction is finished you move the square away from the fraction to the main line using the right arrow key.
I hole this solves the annoying problem of the mysterious squares.
Please read the manual to learn about this feature so that you can decide whether to take advantage of it or not.
Feb 19, 2013 | Casio fx-300ES Calculator
Tip
How can add Horizontal Lines in Document Quickly with Word 2007?
<p><span>With this technique we can add horizontal lines without having to use of the ribbon on the top of the page. It is very easy to add horizontal line in Word 2007 just using the keyboard shortcuts. You will be able to insert many different designs by using the keyboard.</span><br /> <p><span>You can use one of the following methods.</span><br /> <p><span>1.<span> </span>For adding a simple straight line, type three dashes (---) and press Enter. </span><br /> <p><span>2.<span> </span>If you want to add the style of a horizontal line, type three asterisks (***) then press Enter. </span><br /> <p><span>3. You may type three underscores (___) and press Enter for got this line.</span><br /> <p><span>4. For getting this line type three equal signs (===) and press Enter. </span><br /> <p><span>By using these shortcuts you can break two paragraphs in Word 2007, you may to break the numerous sections of a document.</span><br /> <p><span>This is the simply way for using a new character like asterisk, equal, underscores, or dashes, you can add style to the Word document.<b><span> </span></b></span><br />
on Dec 24, 2010 | Computers & Internet
Tip
Have you had problems with enabling FancyUrls in your CMS (Content Management...
Have you had problems with enabling FancyUrls in your CMS (Content Management System)? A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file.
This simple fix is just clearly written to help users better understand what to do, as well as an easy copy/paste job.
  1. Simply copy and paste this code into a new Windows notepad file.
  2. "Save file as.." .htaccess - including the dot in front of htaccess.
  3. Upload the file to your public_html directory, overwriting the previous one if any.
  4. (Not a required step, use only if temp.htaccess exists.) If there is one called temp.htaccess, simply delete that one OR rename it as .htaccess and upload the new .htaccess for an overwrite.
Copy the text below this line..
AddDefaultCharset UTF-8
Options +FollowSymlinks
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule /?([A-Za-z0-9-]+)/? $index.php?id=$1
# Add a ReWriteBase line to any directory or subdirectory requiring it.
# The default directory is "/", which is the root or main directory you use.
------------------------------------End copy
Good luck to you!
on Jul 04, 2010 | Computers & Internet
How do I set date
In any mode, press the MENU button. Use cursor-up/down to highlight Setup (three horizontal sliders) and press the OK button. Use cursor-up/down to highlight "Date & Time" and press OK. Use cursor-left/right to move between fields, cursor-up/down to change them. Press OK when done.
Jan 30, 2012 | Kodak EasyShare Z710 Digital Camera
Tip
Add Horizontal Lines in Word 2007 Document Quickly
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures:
1. If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2. For this style of a horizontal line, type three asterisks (***) and press Enter.
3. Type three underscores ( ___ ) and press Enter to get this line:
_____________________________________________________________
4. Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
on Jun 29, 2010 | Microsoft Word for PC
Cursor jumps when spacebar is hit
This is a problem of Virus attack to your PC you can install an antivirus software and scan your pc for viruses
May 28, 2009 | Dell Inspiron 530s Desktop Computer
G5 Desktop icons, cursor: horizontal lines
Hey Kim,
You most definitely have a video card problem, I have seen it many times. The AHT is different for each Macintosh, which version are you using? let me know the serial number of your computer and the version and I will tell you the correct AHT to use.
Feb 18, 2009 | Apple Power Mac G5 Desktop
Cursor unstable.shooting about
hi, welcome to fixya
if you customize your cursor then that might be a problem because your Norton might detect something wrong in using your cursor. and the another problem is that you install for the customized cursor to run.
please un install your cursor customizing program at your control panel, in add/remove program.
hope this can help you.
God Bless.
Nov 28, 2008 | Acer Aspire 5100 Notebook
Canon ImageRunner 3045 -- One Touch Feature
have you done this at the machine control panel or by browsing to the web interface? You may be able to do it there. If not you are SOL.
Jul 07, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Casio FX9750GII Graphic Calculator Logo
2,625 people viewed this question
Top Casio Office Equipment & Supplies Experts
Ekse
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
